Results 1 to 7 of 7
    Jun 2006
    i'm planning to buy mags kaso yung nakakikita ko sa classifieds palagi may nakalagay na offset at mga pcd100 or pcd114. ano ba mga difference nun? para san po yun? car ko ay vti ano dapat specs nun sa mags. tia
    Jan 2008
    pcd is the distance between the farthest bolts in millimeters (mm). this is part of the bolt pattern. when it says 4x100, that's 4 holes with 100pcd. usually big sedans to bigger vehicles have 114pcd. small sedans and smaller vehicles have 100pcd. there are some exceptions.
    offset is the distance from the bolt face to the center of the wheel in mm. by center i mean if you're facing the tire thread, not the sidewall of the tire. negative (-) offset means the wheel is protruding outwards. this is common for offroad vehicles. positive (+) offset means the the wheel is protruding inwards. this is common for sedans.
    i think the civic vti is 4hx100pcd. not sure about the offset. your manual should indicate the proper offset for your car, but i believe it can handle +35 to +45. note that too much positive offset can cause rubbing of your tires to the wheel wells. i'm sure that +35 to +40 is safe.
    Sep 2008
    Plano ko to buy 15s mags with 195/50 specs. Ano po ba magandang offset para pasok sa fender yung mags and walang sayad?
    Feb 2009
    Quote Originally Posted by richiegonzo View Post
    if you'll go for 15" go for 195/55, not the 50 series.
    Feb 2009
    Feb 2009
    sorry double post..
    And you can always check your car manual
pakilinaw naman about offset at pcd
