Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Feb 2013
    Hello experts! I've tried searching on the Web (and on this forum board as well) and also asked tire shop owners about this.
    On the Web, it says that the new tires should be placed on the Back. See the following links and videos:
    1. Popular Mechanics
    2. https://www.youtube.com/watch?v=gSz7cm6MwH0
    3. https://www.youtube.com/watch?v=oa9hzcjdi5Q
    As for tire shop owners, they say that the new ones should go on the Front for lesser tendencies of "exploding front tires". Is this just a myth then?
    Also, what are good, cheap but reliable brands for tires on a Honda CRV 2003? What's your suggestion/opinion regarding Dunlop, Yokohama, and Bridgestone?
    BTW, I'm using a Honda CRV 2003.
    Thanks!
    Quote Originally Posted by nightfox View Post
    Thanks!
    years ago, it was thought (me included) that new tires should always be installed out front, so that the driver can control the direction of the skidding car.
    today, scientific evidence suggests that, when skidding, control over the car is better if the new, treaded tires, are installed at the rear.
    better yet, buy 4 tires!
    and i am a sucker for locally manufactured tires.
    read this too. the reason being (according to the the article) is that newer tires on the rear will help prevent sudden unexpected fishtailing
    btw, anu-ano ba ngayon ang locally manufactured tires bro?
    pero depending din siguro sa condition ng tires. if the front are worn more than the rear (assuming the rear does not need replacing yet) then replace the front. otherwise replace all 4.
    i just replaced last year the front tires on one of my rides. it was worn 80%, konti na lang angat sa wave pattern ng 5 peso coin. the rear tires are still good for another year when the 5 years life expires.
    Would be wise to rotate tires every 5,000kms so wear will be even & tires will last longer.
    Dec 2002
    Thanks!
    I'm using Goodyear Wrangler HP AW, just last year I replaced the two front tires because those two got punctured sidewall from an accident. Before I was using Goodyear Fortera which is Manufactured here in the Phil. but they discountinued it.
    IMHO, dun mo ilagay sa driving wheels...sa front kung FWD or rear kung RWD. Mas need ng traction dun as compared sa "steering" wheels kaya nga mas madali sya mapudpud.
    Aug 2004
    You always put the new tires on the rear. Always.
    If the old tires that you're not replacing are so old that they might "explode", then you don't want them on the car *at all*.
    If the old tires don't have enough tread to evacuate water (4/32"), then you don't want them on the rear. Hydroplaning front tires are absolutely no problem. The car continues in a straight line until you pass the puddle. At which point you gain back steering and continue on your way.
    Hydroplaning rear tires are a right pain in the ass... and if your hands aren't quick, the car is sideways before you blink. (I've been lucky when that's happened to me... my hands are quicker than my brain).
    The ONLY time you leave the old tires on the rear is if they still have more than half-tread left. If they're anywhere close to 4/32 (slightly taller than the writing on the margin of a 5-peso coin), put them in front.
    If you don't like doing it that way... rotate your tires often, so you won't have to replace your front tires too soon.
    This is what I would tell friends and family when they ask me.
    thanks for sharing bros!
    btw i thought rotation should be every 10k?
    about rotating tires. di ba pag nag rotate ka ng tires, yung nasa front eh malilipat sa likod? so dapat di ka pala nag rotate ng tires, kung susundin mo yung rear should always get the new tire.
    errr...
    rotating tires is one thing.. replacing bald tires is another..
    the assumption is, the tires being rotated are all in good condition.
    Jun 2015
    back sir baka kasi kalbo na din yung back mo tapos on sharp turns baka mag oversteer ka delikado yun sa highway sir. so new tires mo sa back tapos kung makapal pa back tires mo transfer nalang sa harap
    How about for cargo trucks? Should the new tires be placed in front or at the rear?
    I always put the new tires in front for our cargo trucks. I am thinking that there are more tires at the back, 4 or 8, than the front (2 only).
    Signature
    with all due respect..
    cargo trucks are lethal weapons when they skid and/or hydroplane. pag dumulas ang malaking trak, damay lahat!
    if i had any say in it, i would have them impounded if they so much as have one bald tire on them.
    my 98 centavos' worth..
    but in a recent google i made, there was this ... that, in one paragraph about recommending new tires be put up front, delivered two conflicting ideas.. confusing..
    new tires: rear
    old ones: front
    whether front-wheel drive or 4x4, you need the tires with better traction (i.e., new ones) on the rear of the vehicle
    also, the older tires need to be replaced first so put them where they will wear faster
    for technical explanation, go back to niky's post
    Aug 2004
    Depends. If the tires still have enough tread to evacuate water, then it's not a problem if they're on the rear axle. And yes, having multiple tires or tandem tires helps prevent hydroplaning.
    Shouldn't have any tires old enough to be in danger of bursting, however, on a cargo truck.
    Apr 2008
    I'd suggest prioritizing the front wheels regardless of drive configuration. They are always the first ones to wear out since they are the turning wheels, even with rear wheel drive vehicles. Replaced all the Revo's tires around 3.5 years ago with GTRadial Classiro's. Now, around 32tkms later, the fronts were worn down to the point of needing replacement, while the rears still had around 50% tread left in them at least. I've recently replaced them with Falken Sincera's. Excellent grip and significant improvement in handling as compared to the old GTRadials.
    I remember from my toyota
    manual tire totation with spare every 5k. I guess consideration would be if you rarely use the car and ma una yung 6 years before you could evenly distribute yung wear tear with your spare tire. Sayang nman spare tire. Kung overused naman car medyo kakapagod nman yata rotate every other month.
    Apr 2013
    If so, all the trucks in the metro would have been impounded. [emoji1]
Replacing Only 2 New Tires: Front or Back?
