Results 1 to 17 of 17
    Jun 2006
    ang nasa front ay 155/65/14 tapos ang nasa rear ay 165/65/14. ok lang ba to? may magiging problema ba? sa handling or wear ng tires?
    wala po kasi kami makita na 155/65/14 kailangan pa daw iorder wait pa daw 1 month. yan po stock tire size.
    sabi ng tire shop 165/65/14 nalang daw kunin tapos sa rear ikabit at yung nasa rear ilipat sa front. front kasi ang for replacement pudpod na.
    same lang daw yun malapad daw lang ng konti yung 165???
    magkaiba lang sa lapad yan
    pareho height
    Sep 2013
    oo nga sa lapad lang magkaiba pero parehas height
    Jun 2006
    in short po ok lang. pwede po ganun? thanks mga experts
    pwede yan
    di kailangan maging tire expert para malaman na pwede yan
    Feb 2009
    Quote Originally Posted by step22 View Post
    65% of 165 is not equal to 65% of 155
    basta pareho 2 sa likod at pareho 2 sa harap
    the small difference in aspect ratio won't affect the vehicle
    if it bothers you (like coz OC ka) palitan mo 4
    Jul 2011
    Ni hindi mo mapapansin yung kaibahan sa ride quality kung mas malapad ng konti yung likod mo, especially kung FWD ang kotse.
    Apr 2013
    what? where did you get the 65%??
    it's aspect ratio
    165/65R14
    165 is the width of the tire in mm
    65 means 65% of tire width
    so 65% of 165 --- that's the height of the tire
    so a 165/65R14 tire is tiny bit taller than a 155/65R14 tire
    masyado lang technical mga academic
    Kaya hindi ko pinapatulan yung mga academic, magaling sa technical words pero sa application... Kamote.
    Oct 2009
    basta ung sa harap eh magkapareho..ok lang saka sa likod ..
    wag lang may butas...LOL
    Feb 2009
    if your car is two wheel drive, it might be okay if you do not have four channel anti lock brakes. if your car is full time all wheel drive or part time four wheel drive, the tires will fight against each other. if it was full time four wheel drive or all wheel drive, the center differential will be overworked and prematurely fail
    Sep 2013
    I agree with this.
    If you have ABS, the ABS sensor may think that the smaller tire is rotating faster and your ABS will react abnormally.
    While if you have FWD or AWD, your system may think the small tire is skidding since it is running faster which may introduce more wear & tear or possibly, malfunction to your AWD system.
magkaiba tire size front and rear ok lang ba?
