Results 11 to 17 of 17
- Oct 2009
- 2,271
September 15th, 2013 03:21 PM #13basta ung sa harap eh magkapareho..ok lang saka sa likod ..
wag lang may butas...LOL
September 15th, 2013 03:46 PM #14
September 15th, 2013 04:49 PM #15
yep
mas bilib ako sa mga veteran mechanic na walang formal education kesa mga academic na hindi nadudumihan ang kamayLast edited by uls; September 15th, 2013 at 04:55 PM.
September 16th, 2013 01:05 PM #16
if your car is two wheel drive, it might be okay if you do not have four channel anti lock brakes. if your car is full time all wheel drive or part time four wheel drive, the tires will fight against each other. if it was full time four wheel drive or all wheel drive, the center differential will be overworked and prematurely fail
September 16th, 2013 01:11 PM #17
I agree with this.
If you have ABS, the ABS sensor may think that the smaller tire is rotating faster and your ABS will react abnormally.
While if you have FWD or AWD, your system may think the small tire is skidding since it is running faster which may introduce more wear & tear or possibly, malfunction to your AWD system.
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
