Hi,
Just wanted to ask the pros here if anyone tried both tires on 19s?
Im looking for the best 245/45/19, im just not sure if PS4 has that spec
Thanks!!
Hi,
Thanks!!
Pilot Sport 4 > Primacy 4 definitely. More grip (both wet and dry), same longevity as an ordinary tire, quiet on the road.
Just found out today ps4 doesnt have spec for 245/45/19, but im still leaning towards UHP tires, im not open to other brands
Yes bro, anyway too bad just inquired to all reputable shops, got feedback na michelin will be refilling stocks of those tire size 2-3months pa. So im searching other brands.
What about falken azenis? They offer UHP for 245/45 size. And also yokohama rv02. Same price range 11-12k ea
Goodyear F1 Asymmetric 5 and Falken Azenis FK510.
Yan yung mga comparable to the PS4 in terms of performance, comfort, longevity, and price.
Yokohama RV02 not even in the same league. Entry level tire lang yan.
What car are you putting it on pala?
Putting it on FXT bro, wanted to have UHP naman because in the past i always used Touring.
I won’t put such tires on my FXT as it is supposed to be a performance-oriented all-purpose CUV. I guess maybe on a performance sedan or coupe, UHP tires would be welcome. Besides, despite the performance of the FXT, it helps if your tires can take on much harsher surfaces like mud, gravel, or unpaved roads.
I use Bridgestone Duel HP Sport now which is better in terms of grip compared to the stock Dueler HL 400. Since it’s your car and you’re running on 19s, it is used most of the time on paved surfaces, you’re free to use UHPs on an FXT.
There's a Pilot Sport 4 SUV. Just order it custom from a tire distributor since they don't usually carry stocks of that.
MICHELIN Pilot Sport 4 SUV Tires | Michelin Tires Philippines
No point getting a passenger-car Pilot Sport 4 for your FXT. You'll never reach the limit of grip anywhere outside of a track. PS4 SUV also has higher load rating and longer wear.
I will look into this, just got home from Ben’s ok and yea most tires of this size are just “by order”.
Anyway to be more specific im trying to achieve something like thd subaru forester ts that came out of jp and aus. but it uses turanza on 245/45/19 too.
IMO pointless to use UHP tires on a commuter. Starting from my early 20s I've always had something like AD05/06, AD07, AD08 Neovas or Bridgestone RE-11s on my car. Nauubos (and IMO nasasayang) lang sa daily drive, plus they have more road noise and are prone to tramlining. Took me till my mid-30s before I learned that lesson hehe
These days touring tires lang for daily, and have the UHPs (or semi-slicks) on a spare set of lightweight wheels for trackdays. For daily drive even lower tier tires like the RE003 are good enough.
Though the Michelin PS 4S seemingly turns this paradigm on its head again. Good road noise and wet handling, plus close to the same level of grip as most 200-treadwear tires while using a 300-treadwear compound.
Whistler suggested Latitude Sport 3 or Primacy SUV or PS4 SUV. You can check on these models.
Have both RE003 and PS4. Much better longevity and grip on the PS4, despite both priced roughly the same.
I don't recommend the RE003 when you can get a PS4. I don't see any advantages of the RE003 vs the PS4.
Test drive mo at high speeds. Let us know How it performs. I have not reached 15k km yet with my Dueler HP Sports and I will hold on to it for another 21k km.
With my daily commute at SLEX, rarely do I get past 150kmh unlike when you’re in SCTEX where you can do 200kmh or more.
Upgrade ka na rin to Brembo NAO pads. They are better than stock in both slow and fast braking.
