Results 1 to 10 of 12
May 28th, 2007 06:16 AM #1
Mga kabayan,
Got a AMG sport Rims with run flat tires for from my boss' Benz (because he changed rims just because of one tire having a lump, but no damage to rims). .it has five holes, but i dont know if this will fit a Toyota Revo VX. .
Do you think it will fit? if not, there is a car shop here willing to trade it to 16" or 18" BMW OEM mags(with tires), what model of BMW mags would you recomend that will fit in the REVO VX back in Manila?
Salamat po
BATMAN d OFW
PS-forwarder says to ship it via sea freight in one box, do you think i will be taxed for used mags and tires? or should I put them in two separate Boxes?
May 28th, 2007 08:17 AM #2
isn't the Revo 4-lug (holes)?
if so, no Benz or BMW rim will fit it. 5-lug kasi silang lahat eh.
May 28th, 2007 08:34 AM #3
5 holes ang revo. i dont think it will fit without rubbing the inner side of the fender. what is the offset?
May 28th, 2007 08:37 AM #4
ang alam ko 5-lug ang revo and innova.. well certainly the innova is 5-lug. just don't know about the lug spacing. are all 5-lug wheels created equal?
May 28th, 2007 01:37 PM #5
It may not work since Toyota and mercedes have diff. bolt pattern and wheel offset.
May 28th, 2007 02:18 PM #6
parehong 5 lug holes ang Revo ,Innova at Camry"
same PCD din sila
ito ang isa sa dapat mo i consider (PCD)
AFAIK ..iba ang PCD ng benz ng Boss mo diyan ..
REVO ,Camry ,Innova at Adventure share the same PCD ( 114.3 )
May 28th, 2007 03:49 PM #8
Salamat Kabayan!
Hay, sayang, ang ganda ng Mags at run flat tires, pero napasubo na ako at kinuha ko na sa Boss ko eh, benta ko na alng pag uwi ko sa July, kaso mahal ng shipping. .
sayang, pogi pa naman
so check na lang po ako ng camry mags dito
salamat po sa tulong
May 28th, 2007 03:59 PM #9
i have a neighbor that has an FX with benz rims dati. double check mo na lang pcd values.
Tsikot Member Rank 3
- Oct 2006
- 1,069
at 1M... the CHAdeMO plug alone make it difficult for me to consider this car... tapos we all know...
2021 Nissan Leaf
