Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    May 2007
    Mga kabayan,
    Got a AMG sport Rims with run flat tires for from my boss' Benz (because he changed rims just because of one tire having a lump, but no damage to rims). .it has five holes, but i dont know if this will fit a Toyota Revo VX. .
    Do you think it will fit? if not, there is a car shop here willing to trade it to 16" or 18" BMW OEM mags(with tires), what model of BMW mags would you recomend that will fit in the REVO VX back in Manila?
    Salamat po
    BATMAN d OFW
    PS-forwarder says to ship it via sea freight in one box, do you think i will be taxed for used mags and tires? or should I put them in two separate Boxes?
    isn't the Revo 4-lug (holes)?
    if so, no Benz or BMW rim will fit it. 5-lug kasi silang lahat eh.
    5 holes ang revo. i dont think it will fit without rubbing the inner side of the fender. what is the offset?
    Aug 2003
    ang alam ko 5-lug ang revo and innova.. well certainly the innova is 5-lug. just don't know about the lug spacing. are all 5-lug wheels created equal?
    May 2007
    It may not work since Toyota and mercedes have diff. bolt pattern and wheel offset.
    May 2005
    parehong 5 lug holes ang Revo ,Innova at Camry"
    same PCD din sila
    ito ang isa sa dapat mo i consider (PCD)
    AFAIK ..iba ang PCD ng benz ng Boss mo diyan ..
    REVO ,Camry ,Innova at Adventure share the same PCD ( 114.3 )
    Dec 2003
    iba PCD ng benz, also bimmers sa japs
    May 2007
    Salamat Kabayan!
    Hay, sayang, ang ganda ng Mags at run flat tires, pero napasubo na ako at kinuha ko na sa Boss ko eh, benta ko na alng pag uwi ko sa July, kaso mahal ng shipping. .
    sayang, pogi pa naman
    so check na lang po ako ng camry mags dito
    salamat po sa tulong
    Jan 2003
    i have a neighbor that has an FX with benz rims dati. double check mo na lang pcd values.
    Bim ko dati 100 pcd don't know bout the new ones
Help po Kabayan: Will AMG 171 18" rims fit Revo VX?
