Results 21 to 40 of 44
    Apr 2014
    #21
    according to their infomercial, they claim to supply the bulk of the oem requirements of the philippine automotive industry.
    Are they still? Enkei ata karamihan ngayon.
    Pero when we had the big body, i was surprised to see that the oem wheel has a rota stamp on.
    #22
    Quote Originally Posted by chronicle View Post
    i do not know.
    i took a look at my oem mags downstairs just now.
    i couldn't see who manufactured it.
    Apr 2018
    #23
    Quote Originally Posted by Salanguit View Post
    Alam ba ng shop na bibilihan mo ng rims and gulong ang match or recommended na sukat sa kotse mo?
    bakit po napakahirap hanapin ang mags na 4 holes PCD 108? para sana sa Ford Ecosoprt ko
    Apr 2014
    #24
    Quote Originally Posted by Solitaire View Post
    Dahil ford lang ang mayrong ganyang config.
    Karamihan is 4x100 and 4x114.
    Check mo concept one.
    Apr 2018
    #25
    salamat sir sa advise,
    may mga nababasa ako na magkakaroon ng problema kinalaunan pag gumamit ng wheel spacer
    Apr 2014
    #26
    Pwede. Pwede hindi din.
    Pero mas mainam, bili ka nang hub centric ring para sa pcd ng ecosport at pcd of your chosen mags. Sa amazon marami.
    Apr 2018
    #27
    sir pagsasamahin sa spacer yung hub centric ring or pwede ring lang ? pasencia na newbie po kasi sa auto
    #28
    Spacers are meant to reduce offset or bring your wheels out closer to fenders. Avoid the universal ones. Sample of a 4pc set of 5mm pcd 4x108/63.4 hub:
    https://www.amazon.com/gp/aw/d/B074R...LxL&ref=plSrch
    Beyond 5mm thickness, go for longer the lugs. Sample of a 15mm thick set w/ longer lugs...
    https://m.ebay.com/itm/H-R-Trak-DRS-...-/183188978468
    Hubcentric rings are meant to adapt your aftermarket wheel's hub bore to the ecosport's 63.4mm hub diameter to prevent vibrations at speed. If your new wheels have the common 73.1mm hub bore, choose 73.1-63.4mm hubcentric or spigot rings like this set...
    https://www.amazon.com/Hubcentric-Ri.../dp/B00F3QTYSU
    Always choose alloy over polycarbonate ones.
    Apr 2018
    #29
    Amazon.com: Customadeonly (4) 5mm 3/16 Hubcentric Wheel Spacers | 4x18 63.4mm Hub | No Hub Lip: Automotive
    Amazon.com: Hubcentric Rings (Pack of 4) - 63.4mm ID to 73.1mm OD - Silver Aluminum Hubrings - Only Fits 63.4mm Vehicle Hub & 73.1mm Wheel Centerbore: Automotive
    Thanks and appreciate a lot for shedding lights on this matter sir, may idea na po ako
    #30
    Anytime, sir. I haven't backread so I dunno what your plans are....just measure the offset required properly to find the perfect wheels or determine the spacer thickness needed. If you can go wothout spacers, it's more ideal.
    Apr 2018
    #31
    Got a Ford Ecosport Ambiente, planning to change my stock metal rim 15" 4x108 pcd to mags/alloy with the same specs, my stock tire is 195x65 (yan narin sana gamitin ko which is still 90%) done a lot of internet searching, most of the models i like are 4x100 and 4x114, am hesitant to use spacer, check ko na lang muna siguro concept one shop and mags shops along Banawe
    #32
    If you're looking for alloys, won't you consider used stock?
    https://www.*******/item/ford-ecospo...l?h=3213beb681
    #33
    This is a good suggestion. The stock rims of the Titanium Ecosport look good. Even the rims of the Trend are acceptable already.
    Apr 2018
    #34
    yes sir i would definitely consider using stock from Trend, Titanium is a bit expensive, there are several sellers i'd seen posting on FB selling their stocks and it's selling like a pancake (ambilis mabili) and sometimes they sold it individually (for spare) leaving 2 or 3 pcs.or even 1 available and i do need 4, antay antay na lang at marami pang ecosport owners na mahilig magkamot jan
    pag medyo naiinip na, maybe i'll check one of my friend's FORD Fiesta stock, also the same specs but i need to trade in my tires, mag size is 16"
    PS sir i couldn't open the link or maybe its my firewall blocking it
    Apr 2018
    #35
    it's truly a good suggestion, using those stocks is safe as i don't have to use spacer or hubcentric ring, i would settle with Trend, Titanium is a bit expensive
    Apr 2018
    #36
    Look for autobots shop. veteran workers and ang gaganda ng rims nila madaming pagpipilian :D
    Apr 2018
    #37
    Quote Originally Posted by Jhnlsm View Post
    saan po location nia?
    Apr 2018
    #38
    buy branded, from authorized outlets. google them, sir.
    'tis the only way, one can be reasonably assured that the product ain't fake and is of good quality.
    i'm not saying the less-known brands are bad. but there must be a reason why they're selling for cheaper.
    just want to ask for help.. do you know where to buy wheel adapters from pcd 139 bolt pattern to pcd 114 wheel/rim pattern? p;ease guys need help
    #39
    Quote Originally Posted by bob vios View Post
    Why not sell the 139s and get the 114s?
    Apr 2018
    #40
    Quote Originally Posted by mda View Post
    yes thats corect but still looking for a remedy if i can still use the 114s in a 139s bolt pattern. is it possible that i can find an adapter.
HELP about rims and tires
