Results 1 to 20 of 21
    A quick repair from the Dunlop Center(not in m. manila)
    Nail head was severed off, sharp end was left and it was in the middle tread. 20psi this morning. At first the guy was saying no bubbles including the tyre valve. So I told him to increase the tyre pressure. Lo and behold really small bubbles were super slowly forming.
    1. scuff surface and clean off inside aka prep surface
    2. tyre glue, and let it dry
    3. set patch
    4. roller out air
    Jan 2008
    Hmmm.. medyo newbie yung repair guy nila.. SOP dapat na increase tire pressure to check for leaks
    its a given. we rise up to any occasyon
    hhmm if im losing 2-3 psi monthly, may leak na kaya yun na ganyan kaliit?
    kaso halos lahat ng gulong ko ganun eh O_o
    Sep 2012
    wala yan bro normal yang ganyan kapag on a monthly basis lahat sila pamtay magbawas.
    ang hint sa ganyan para malaman mo kung alin yung may maliit na leak is kung alin yung may pinaka malaki usually 4psi and up difference ang bawas sa hangin once nag refill ka
    Quote Originally Posted by jodski View Post
    or di kaya lahat sila may leak? hahaha
    btw ok lang ba di palitan yung PITO ba yun, kahit more than 6 years old na yun rims?
    May 2018
    BTW, OT ito pero share ko lang yung napanood ko kanina.
    Mga sira-ulo, gumawa ng gulong sa duct tape:
    We Made A TIRE Out Of Duct Tape - YouTube
    Then di pa nakuntento, gumawa din out of rubber bands...
    We Tried RUBBER BAND Tires - YouTube
    Tumakbo naman! although yung 2nd, sigurado deformed yung rim/magwheels mo diyan pag tagal.
    Feb 2014
    it's rare to find a competent tire tech they jack your car at the wrong points. they don't allow enough time for rubber cement to dry. they don't use bead lubricant. their gauges are incorrect. they scratch your rims. they over-torque your lug nuts.
    Apr 2004
    Any recommendations for good tire tech places?
    Quote Originally Posted by morrissey_05 View Post
    servitek 250 daw
    Jul 2013
    Quote Originally Posted by Vodka View Post
    Who uses rubber cement for tire puncture?
    AFAIK, there is a reason it is called "vulcanize". No adhesives needed because the vulcanization process is a chemical reaction thing.
    Feb 2014
    Quote Originally Posted by Lew_Alcindor View Post
    vulcanization, from the god of fire vulcan. needless to say lots of heat and sulfur etc. turns natural rubber etc into tires that don't melt into a gloopy mess
    when you get a puncture you don't do this process again. you just stick on a patch. see youtube. you really don't wanna heat up a tire to patch it
    flucking nuts.. same tire. different location. damn roads🤯
    baka may magnet yung gulong mo bro hehehe
    Sep 2005
    S&R tire service.. don ako parati nagpapa vulcanize.. and if you buy your tires with them, free ang vulcanizing and nitro for the life of the tires..
    ikaw ba yan doc? [emoji28]
Tyre Patch Repair
