Results 1 to 10 of 26
- Dec 2012
- 25
September 4th, 2013 01:42 PM #1i have 185 55 R15 good year nct 5 tires and they are all 5 to 7 years old already and im planning to change them. that size are hard to find and expensive. Can I change size to 195 50 R15 using the same rims? or please recommend me a good tires that fits to my rims and yet good quality and budget wise. I prefer Indonesia or japan made, no to china and taiwan brands.
September 4th, 2013 02:06 PM #2
good day! for what car sir?
195/50 R15 is fine, been using it for years on my EK SiR. if you prefer the stock / non lowered look, 195/55 will do fine. just make sure the rims are wide enough to accomodate the new tires.
Japan tires are plenty. indonesia brands, i prefer gajah tunggal.
Sent from my Cherry OHD using Tapatalk 2
September 4th, 2013 02:15 PM #3
- Dec 2012
- 25
September 4th, 2013 02:25 PM #4
September 4th, 2013 02:32 PM #5
dont know if its just me but ive seen more choices on a 195/55 versus 50s.
September 4th, 2013 02:48 PM #6
Try to check out Kumho Solus series and compare the price baka naman makakuha ka pa ng reasonable deal getting the same size na gamit mo.
By experience and personal preference lang its either Yokohama A drive or Kumho Solus. Plus side ng A drive tahimik and maganda talanga handling while sa Solus naman medyo maingay pero above average pa rin naman performance and mas mura sa A drive.
Your call naman sir on what to get and good luck hunting for a new set of wheels
September 4th, 2013 03:09 PM #7
September 4th, 2013 03:45 PM #8
* Diameter inches (mm):
Old (185/55/R15): 23.01 (584.5)
New (195/50/R15): 22.68 (576)
Difference: -0.33 (-8.5) -1.5%
The difference says that the Tire Diameter was reduced by 1.5% (-1.5%).
So, pasok pa siya sa "rule of thumb" in choosing the right tire size (+/- 3%).
Usually, 'pag more than 3% kasi, you might need some modifications to avoid "rubbing". hth.
- Dec 2012
- 25
September 4th, 2013 03:52 PM #9ill try to search that one sir, thanks
September 4th, 2013 04:05 PM #10
there are certain websites that helps you calculate the allowable tyre size.
Tyre Size Calculator
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
