Quote Originally Posted by 20vanda01 View Post
My current mags size is 15x6.5 wrapped with a 235x75 Bridgestone Desert Dueler.
I got a plan to put a wider mags/wheels which is 15x7 or 15x8, but will use the same tire I have.
Any inputs? Pros/Cons?
For those sizes, there aren't many issues. You'll just have to check that the offset is similar or identical to your current mags so that you won't have any problems with fender rubbing... with a 15x8, it might rub no matter what the offset, but on an AUV/SUV/CUV, likely not, unless you're running with way too much cargo.
