Results 1 to 8 of 8
December 18th, 2007 01:02 PM #1
What would be a good/best tire size for a stock 14" rim for esi. Stock 185/65/14 na ang nakasalpak.. may masmaganda pa ba na size na bagay sa esi? Thanks a lot.. Merry Christmas!!
December 18th, 2007 01:11 PM #2
December 18th, 2007 01:20 PM #3
- Dec 2007
- 18
December 18th, 2007 02:49 PM #4Rim Diameter: 14 in
185/65 205/65 195/60
Section Width: 7.28 in 8.07 in 7.67 in
Rim Width Range: 5 - 6.5 in 5.5 - 7.5 in 4.5 - 7.5 in
Overall Diameter: 23.46 in 24.49 in 23.21 in
Sidewall Height: 4.73 in 5.24 in 4.60 in
Radius: 11.73 in 12.24 in 11.60 in
Circumference: 73.70 in 76.93 in 72.91 in
Overall Diameter Difference: + 4.21% - 1.07%
If you change from 185/65 to 205/65
* the brakes might not be able to handle the bigger tires
* loss of torque (slower acceleration due to bigger diameter)
* the wider and higher tires might hit the fenders, frame and coilsprings
* may need to adjust wheel alignment and camber
* the wider tires might be too wide for the stock wheels
* wider tires mean higher gas consumption
If you really want to change the size of your tires it's better if you pick 195/60. Your tires will look a little wider and a little lower without sacrificing your suspension settings and the integrity of your braking power. Since the diameter of 195/60 is smaller, expect a very little increase in gas consumption because the tires will be rotating more per kilometer.
KBR is right, the stock size is still the best.
- Dec 2007
- 18
December 18th, 2007 03:00 PM #7
December 18th, 2007 09:56 PM #8
ok thanks.. ill go for the 195/60.. medyo payat ksi yung 185 na nakasalpak. parang nakapasok yung mga gulong sa fender sa likod..
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
