Results 1 to 6 of 6
    Dec 2007
    i just bought a new tires for my hilux but my rims is a stock w/c is 15".. is it ok if i change my rims to 16" but my tires is compatible w/ a 15" rims? tnx.. planning to get the grid offroad from rota.. where can i buy the rims and how much is it?
    So you want to get 16" rims but use 15" tires on it? If that is your plan it will not fit your tires will be too small to fit a 16" rim.
    Dec 2007
    yung rota rims b magaan?
    Aug 2004
    Typically lighter than stock rims, the difference depending on the size. 15" tires will not fit on 16" rims... I mean, you might actually be able to stretch them over the rims, but the bead will crack and break and you'll be left with a pretty useless piece of rubber.
    i wonder how long will that thing last
    Dec 2007
    oki tnx.. merun [po b 15" gridoffroad rims? anu maganda brand na rims.. yung magaan n cheap lng pro astig tignan n nd madali masira rough road kc samin.. naka 32" maxxis bighorn tires ako.. tnx..
15" tires on a 16" rim?
