Results 1 to 8 of 8
November 20th, 2013 06:23 PM #1
Fellow Tsikoteers, good afternoon!
I posted a question sa isang thread dito. It's about fuel filter replacement for a 2008 Sportage CRDI.
Napagawa ko naman sa isang shop sa may Motortown, ATC. Isinabay ko na sa change oil. Okay naman, di naman gaano kadumi yung fuel filter.
Nung matapos ang service, pinatanggal ko yung engine cover to sheck a leak that was spotted by the previous mechanic who did the oil change.
Now, as expected, andun pa din. The leaks are from the injector tubing or fitting na but mostly sa may high pressure pump. Nung sabihin ko sa
mechanic na I experience some engine noise (somewhere between humming and rattling) during low rpm's, baka yun na nga daw pump ang may
diprensya. DI naman nila daw kaya yun kse wala sila diagnostic or calibration tools for CRDIs.
Any advice po? I also read somewhere here (sa Hyundai forum) na meron nagparepair ng HP pump. Baka meron senyong nakaranas ng kaparehas ng case ko. Maganda pa naman manakbo, esp. pg highway cruising speeds, banayad at di maingay. At di rin naman nagbago ang consumption as before the rattling at low rpm's, nasa 11-12 mixed. Pero ung ingay nga at yung leaks ay syempre cause for concern
Please help. Thanks in advance.
November 20th, 2013 07:06 PM #2
better ask dieseldude baka naka-repair na siya ng ganyan. hp pump yan, yung maliit na leak will eventually eroded the sealing faces and cause an irrepairable leak.
November 21st, 2013 10:17 AM #3
Thanks, Sir Yebo.
Medyo malayo yata shop ni sir dieseldude, QC ang nasa profile nya. But I'll ask na din.
Thanks again.
February 17th, 2014 03:04 PM #4
Up ko lang,
Bukod sa Central Diesel, meron pa ba ibang shop with a similar service reputation (positive) somewhere here sa southern part of the metro, or better yet in Batangas?
I inquired in one diesel service shop here in Alabang and the quoted price for check-up and test is already almost 6K, wala pa repair or replacement yun. And I have not seen any recommendation on the shop, unlike Central.
Thanks ulit sa mga replies.
March 11th, 2014 05:24 PM #5
Update: I finally brought my ride to Central Diesel. The common rail pump was inspected and they advised repair (Thank God, hindi replacement). Sir dieseldude was even accomodating enough to show me the HP pump diagram and what the repair kit looks like.
So now, okay na yung problema ko about the HP pump.
Kudos to central diesel, highly recommended to all diesel-fed (especially crdi) car owners like me.
March 11th, 2014 06:04 PM #6
March 12th, 2014 11:49 AM #7
Sir Louie, eto ang address ng Central Diesel:
1176 Quezon Avenue,
corner Scout Magbanua St.
Quezon City, Metro Manila
Pag along Q-Ave ka na going to Edsa, malapit-lapit na after Araneta Ave. Nasa right side yung shop, blue-gray building.
Or call them for an appointment. May website nga pla sila, google mo na lang.
Pag nagpagawa ka, hanapin mo si Sir Toto or Sir Jake. Sabihin mo, inirefer kita, baka makakadiscount ako sa susunod kong pagawa, heheh.
Good luck! Btw, parehas ba nung sakin ang naging problema mo?
For the cost, i-PM ko na lang sayo.
- Sep 2011
- 626
March 17th, 2014 10:03 PM #8Sir Jan2X baka pwede pa pm din ng price sa central diesel. Baka ipacheck namin yung tucson e.
Nagpa calibrate ka ba sir?
Getting a toyota would be ideal mostly for those looking for practicality or one who will use it...
China cars
