Results 1 to 4 of 4
- May 2007
- 7
January 29th, 2010 06:54 PM #1Mga sir,
ilan psi or specified fuel pressure po ng carens na 1.8 or 2.0l gas na carens.
Para malaman ko po kung need ko kailangan magpalit ng fuel pump o hndi kc hndi na ung priginal pump ung nakakabit.
Black smoke kc lumalabas na usok. Sabi ng ibang mechanic to much pressure kc minsan dahilan.
Malakas sa gas ung oto ko nasa 5-6 km / liter ako.
Thanks.
January 29th, 2010 10:13 PM #2
IMHO, if you're car is a gas variant.. Baka hindi lang fuel filter ang kailangan mo check.. I would suggest bring it to a casa.
January 29th, 2010 10:27 PM #3
Too much pressure? Not for an EFI engine. Not usually. It's more likely an issue with your sensors. The casa should be able to check for codes that will point out what's at fault.
If you have no idling issues, then it could be an O2 sensor or MAF issue... or even a bad sparkplug.
January 29th, 2010 11:17 PM #4
looked for the video. it would seem, according to the video, the car in question was purchased by...
China cars
