Does anyone have an idea what this modification is? 2007 xti.
Paano pinapagawa yung smoked? Is it an assembly or just a stick on to stock head lights?
google mo lang, daming gumagawa niyan.. . . smoked headlight. . . search mo rin dito sa forum kung san sila nagpasmoke. . . how about changing your headlight to projector type like that of 2010 model. . .
Smoked and ambered headlights yan.
Open the headlight assembly. Paint flat black the chromes ( except the reflectors ) then paint the reflector of the turn signals orange.
You can DIY that, pero baka hindi mo maseal ng maayos. Marami naman shops na gumagawa niyan. Handazer and north customs to name a few. Im not sure kung pati si xenon optics gumagawa nun.
Mahal yung retrofitted projectors, pero superb ! Retro costs 30k, depends pa on the materials used. Can be cheaper can be more expensive. ;)
Pero kung may budget, hell, go with it !![]()
Thanks for your inputs. May natutunan na naman ako. Pero di ko muna papasmoke, binubuksan pala e.
nag inquire ako before para sa projector retrofit para sa xwind natin and na quote ako for 23k 3-4 days gagawin.. check mo tong website nila.. http://nighthawkperformancelighting.com/main/?cat=1
i have plans to upgrade din pero ipon mode muna
^ Ah, nighthawk, yes.
Kung gusto mo, try to contact garyq of tsikot din. ;)
He has a thread here .... all his works are posted there.
http://tsikot.yehey.com/forums/showthread.php?t=67675
Though makakamura ka if you opt for the bolt-ons, yun nga lang, the range is not that far as compared to retrofits. ;)
Mga sir! Pwede kayang pa smoked yung H.lights ng 02 xuv ko para mabawasan yung "Liwanag ng HID HI/LO (55watts)na pinakabit ko? or hindi siya advisible at papangit lang?!
sir i own sportivo xmax
plan ko rin gawing white light Fog light ko. meron po bang replacement na direct change lang sa bulb para maging white light na?
my additional questions:
- ano po ba yung cool white efect head lamps bakit hinda sya white sa actual? do i need to replace it with HID na di na kailangan ng retrofit? direct Fit po kaya yun parang change lang ng bulb without worries sa compatibility as long as same voltage?
- ano po ba yung mga sizes ng ilaw ng Crosswind/sportivo di ko kaso ma gets yung H1 H4 H11.
marami pong salamat.
gusto ko rin sanang magpalagay ng Angel Eyes saka yung Volvo look na headlamps. Saan kaya may gumagawa nito and magkano? Any ideas.?
I've seen hundreds of works by North Customs on the net. He smokes, ambers & adds angel eyes. Link is http://northcustom.multiply.com/
For converting or retrofitting hid for projector lamps si www.hidretrofit.net
HEADLIGHT BULB CROSS REFERENCE (Sizes are imprinted on headlight lenses or check your owner's manual)Here's an expample: My 2002 Crosswind uses an H4 type of bulb for headlights & an H3 for the foglamps.
- An H4 bulb is also referred to as a 9003 or an HB2.
- A 9004 bulb is also referred to as an HB1.
- A 9005 bulb is also referred to as an HB3.*
- A 9006 bulb is also referred to as an HB4.
- A 9007 bulb is also referred to as an HB5.
- H.I.D. bulbs are referred to as 9500, D1R/D2R, and D1S/D2S.
- H1, H2, H3, H7, H8, H9, H11, and 9008/H13 bulbs are usually referred to as such.
