Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
    Dec 2010
    #21
    mga sir, may problema na naman ako. Had it calibrated last week para sa white smoke pero bumalik ulit white smoke tpos isa pang problema ko minsa parang nahihirapan umarangkada khit na tumatakbo na ng matagal. kapag tatapakan ko silinyador parang yung 80% ng silinyador ko e walang laban/hatak o bisa kaya kelangan ko pa idiin ng husto tapak ko. ano kaya problema? dalas pa naman biyahe ko sa Cabanatuan-Isabela and Cagayan. Mga sir, tulong naman. Dinala ko na din sa Isuzu BMD-Cauayan City Isabela pero ganon pa din. Laki na gastos.
    #22
    The white smoke on the Crosswind is something that has no permanent solution. Change the oil and filters (air/oil/fuel) and it will go away for a while. Don't worry, it's not the only car like that. Mitsubishi 4d56 and Toyota 1HD-T's are also like that since they all belong to relatively the same [ancient] era where emissions standards were less stringent and engines didn't need to talk to a computer to actually do their job.
    Yes, the Crosswind is slow as molasses. My friends have Crosswinds (XT manual and XUVi matic both with turbo engines). Both are so slow that when my boss (in his 97 Land Cruiser 1HD-T) and I drove from Subic to Zambales, the Isuzu XUVi I was driving was struggling to keep up all the way while my boss was merely driving in a relaxed mode.
    Jan 2008
    #23
    Lalo na sa winding roads, mabagal at nakakatakot yan crosswind, parang babaliktad sa curve. Bukod sa ancient na un makina, hilaw na hilaw ang technology ng A/T ng crosswinds.
    Feb 2011
    #24
    i was again disappointed on my 2010 sportivo. i recently discovered that there were paint peeling off on both sides of the rear doors & the differential is also corroded, to think that it's just a year old. then the accelerator pedal began emitting this squeeking sound just like that of a jeepney!then when i was waiting for my wife from the grocery with the engine on idle, upon shifting to 1st gear i have to floor the gas pedal to move the vehicle. is it beacause of dirt/water accumulating in my fuel filter?
    Feb 2010
    #25
    Quote Originally Posted by atly View Post
    I have experience like this. . .convoy kami bayaw ko sa NLEX, he was using ford escape, ako XUVi 2004. . . ako im cruising at the spped of 90-100. . . sabi nya sya naman ay around 100-120 na. . . could it be na medyo conservative lang meter ng crosswind pero actually mabilis na sya?
    Pansin ko rin kasi sa coastal road, eto ang daily route ko, 80kph lang takbo ko pero ang dami ko ng na-oovertake na cars. . . (baka lahat sila 70 lang ang takbo, ). . .
    paps Orly, finally, tutoo ang kutob ko... also experienced the same scenario.. my wife is driving our corolla at around 75 - 80 kph daw and i'm driving our crosswind at 55 - 60 kph lang pero we are running side by side nun ah... so most probably na medyo conservative ang seedometer natin???
    #26
    mejo nakaka relate ako kasi ganun ata takbo ng XUV namin everytime malapit na mag 5k (change oil time!) pero after change oil mejo umaarangkada na ng maganda.
    i've seen some post of sir Benz and others na palitan dapat yung mga filters air/fuel/etc. mukang eto yung namimiss ng XUV namin. tuwing nagpapa change oil kasi isang filter lang yung pinapalitan sa shop. kutob ko mula 2002 hindi pa napapalitan yung ibang filter dahil di naman sya casa maintained.
    i feel kailangn ko na ito papalitan ASAP before anything bad happens.
    anong air & fuel filter ba dapat kong kunin?
    #27
    Quote Originally Posted by chitobarba1972 View Post
    sir ang pagkakaalam ko yung mga crosswind na hindi malaki yung gulong (235 60 r15) ay mas accurate yung speedometer reading nila compare sa mga naka malaking gulong...same principle lang kung mag upgrade ka ng bigger tire even 20" or 22" na gulong may change sa reading ng speedometer... sa pagkakaalam kulang po...
    Feb 2005
    #28
    Quote Originally Posted by kaioz View Post
    Tumpak! A clogged air filter would have adverse effects on air engine intake. A clogged oil and (moreover) fuel filter (since alam na natin na di malinis ang local diesel fuels natin sa Pinas) would have too.
    I'd say get the genuine filters by ISUZU. Should there be "alternative brands", that may do so but I wont vouch on it's reliability.
    Jan 2008
    #29
    Quote Originally Posted by dh0n View Post
    The best way to measure kung accurate ang speedometer mo is to use a watch. Imaintain mo sa 60 kph ang speed then tingnan mo kung sa loob ng 60 sec e makaka 1km ka sa trip meter, ibase mo bale sa km post sa kalsada.
    Hindi magkakaron ng malaking difference sa accuracy ng speedometer kahit na magpalit ka ng bigger o smaller rims as long as ipapair mo un sa tamang size ng gulong, kailangan close pa rin un value ng total diameter ng gulong dun sa stock diameter
    Feb 2010
    #30
    Quote Originally Posted by kkreuk18 View Post
    paps I believe my tires are the same size as stock (235x70 r15) for XUVi, kasi nung nagpalit ako, I bought the same brand and size.. I'll try your suggestion in using a watch, thanks
    Jan 2008
    #31
    Kung di nga accurate yan auto mo e baka pang xt, xto, xti ang gear na nakakabit sa tranny mo, pang small diameter. Guess ko lang naman
    Sep 2010
    #32
    mahina talaga sa arangkada...kahit yung 2005 sportivo ko...pero madali lang naman makabwelo....kaya agad pumalo 100kph-120kph...nakikipaghabulan nga sa strada......at saka kahit kurbada pa yan,nasa driver din siguro...pero pag dating sa ahon,iwan syempre...mabagal talaga sa ahon ang crosswind......para nga lang ako nakatigil pag na overtake etong tulad ng mga strada at dmax sa ahon e......lalo sa IMI old zigzag road quezon...
    Jan 2008
    #33
    Taob ang aabutin mo sa crosswind pag di ka kumain ng lane sa kurbada. Lalo na un mga kurbadang walang banking.
    #34
    Quote Originally Posted by acergy09 View Post
    Kapag ganyan,- alagaan mo na lang at makakaahon din iyan mga bros....
    12.5K:soccer:
    Feb 2011
    #35
    i agree with you sir regarding the sluggish acceleration, mine is a 2010 sportivo m/t. average speed is just around 80kmh & tried to reach 100kmh on the highway pero hindi ko pa tinudo as i have kids onboard.just got it last year & i already posted a lot of complaints to isuzu but anyway i brought it back to the dealer & had everything rectified including replacement of fuel filter which should be done every 15000km.hindi pa nga umabot sa akin, 12954 lng to be exact. but overall performance, i'm still contented with my ride eventhough marami na akong nakitang defects. everytime I have an outing with the whole family sulit din as it can carry both my family & our things.it's engine isn't built for speed anyway, it's built to carry people.
    Mar 2011
    #36
    jowel
    XUV ko mahina umarangkada
    To all: Any inputs or suggestions on my XUV......
    Got my XUV 2003 A/T ....Mahina po humatak hirap sya during start especially uphill mahina umarankada as in dapat apakan mo madiin talaga gas pedal para umandar...What seems to be the problem po... Do I need to change clutch lining? Feel free naman po text me at 09228161131 or message me here...
    Tnx,
    More Power to Tsikot...
    I had this 2003 XUV mahina tlaga humatak manual pa yung sakin but if di ka pa nagpapalit ng ATF you should do it now..1 more thing dpat kasi lagi bago ung air filter mo..On SLEX im running 120kms max speed sobrang hirap humatak tpos my uphill na going down to 90-100 nlng so ung nag tune up and palit air filter medyo naging ok na..Sana makatulong... :D
    Jan 2011
    #37
    Grabe!laki ng natipid mo.Dapat kasama lagi sa pinapalitan ang fuel at air filters sa pms ng sasakyan para laging maganda ang performance ng ride natin.Ang problema sa orig na air filter ay siyempre pa yung mataas na presyo,pero kung gusto nyong makatipid,imodify nyo ang air filter assembly sa pang ELF truck dahil mura lang ang filters nito at malaki pa.Mas malinis na air filter,mas fuel efficient na makina at mas malinis na exhaust.FC will suffer when air filter is dirty.Di rin tayo makakatipid sa di pagpapalit nito sa bawat pms.Ang fuel filter ay pwedeng umabot sa 15k kms bago magpalit.Ugaliin lang magrefuel sa malilinis na gasolinahan.
