Results 1 to 7 of 7
- Jan 2011
- 58
June 19th, 2011 08:10 AM #1Peepz, alam nyo po ba kung kelan nagpaparepack ng wheel bearing? ano po ba ang symptoms na dpat na po sya iparepack? thanks much
June 19th, 2011 08:18 AM #2
for sealed wheel bearings as with FWD vehicles, as the name implies does not need to be repacked but the non driving wheels will have to be. usually, everytime you do brakes inspection and assessment, you repack non sealed bearings with the service. around two years or 30000 miles. if the vehicle had been submerged in flood, it is customary to have your brakes inspected. if the bearings make noise, check and if there is any evidence of discoloration, mechanical damage or roughness, the bearing as a set will have to be replaced-bearing cone and rollers and the bearing cup. they are sold as a set and match mated during manufactureLast edited by ghosthunter; June 20th, 2011 at 09:40 AM.
- Jan 2011
- 58
June 19th, 2011 08:27 AM #3i see, coz last week i heard a loud squeaking noise on front left wheel while driving. when i reached NLEX and hit 100kph the noise was gone and noise never came back after that. i drove it on a new placed asphalt road right before i hear that loud noise by the way.
June 19th, 2011 09:03 AM #4
Squeaking? Hmmm, does not sound like a wheel bearing that needs repacking to me. Have your front brakes opened the thoroughly cleaned. Baka may duming nasingit between the rotors and the pads.... A shot bearing duefor repacking kasi "ugong" ang symptom at tuloy-tuloy.
- Jan 2011
- 58
June 20th, 2011 09:08 AM #5
June 20th, 2011 10:34 AM #6
- Jan 2011
- 58
high idle RPM at engine start
