Results 1 to 7 of 7
- May 2004
- 903
July 19th, 2007 12:29 PM #1Ano po kayang fluid/oil ang ginagamit sa transmission and gear oil for my Hilander. Got my ride 2nd hand kaya gusto ko na din palitan. Plus yung Brake/cluutch and power steering fluid pwede ba palitan? Kaya ba DIY yun? Baka may parang manual kayo yan. Thanks.
July 19th, 2007 12:55 PM #2
base sa highlander crosswind manual, 15-40 viscosity ang pang m/t fluid. since 10 years na rin yan pwede na ang sae 90 para kumunat ng konti. same na rin sa differential. masyado malapot ang 140.
brake and clutch can be bleed and replaced by your suking mech. or sa mga brake specialist.
re: power steering fluid? medyo maselan kung complete bleeding dahil baka magkahangin ang
linya kung diy. ako sa reservoir na lang ako nagpapalit using syringe. mas madalas mas mabuti.Last edited by XTO; July 19th, 2007 at 12:58 PM.
- May 2004
- 903
July 19th, 2007 01:37 PM #3Diba ang 15-40 pang engine oil yun? Eh yung mga ginagamit sa mga Gas station yung pina pump pa nila ok lang kaya yun?
July 19th, 2007 02:53 PM #4
Yep, same with motor oil ang gamit ng crosswind sa manual tranny and you need an oiler para dito kung DIY. sae 90 or 140 lang yung may dispenser sa gas stations.
- May 2004
- 903
July 19th, 2007 03:44 PM #5Ah ok lang din kahit sae90 gamitin ko for both gear oil and tranny oil. Medjo hirap mag shift minsan e. Thanks po... Pero pwede rin yung 15-40? Ano po yung oiler?
July 22nd, 2007 12:37 PM #7
I also have a Hilander every ilang kms ba ang papalit ng oil ng transmission & differentials tama ba spell ko? Hindi pa ako nakakapagpalit ng oil nito mula nung nabili namin yung sasakyan secondhand kaya wala din ako manual. Pero ok pa naman when shifting gears malambot pa naman. thanks!
high idle RPM at engine start
