Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
    #21
    Quote Originally Posted by SiRbossR View Post
    Bro, it's a BIG difference. The Toyota has a CRDi. Delivery of power is entirely different.
    Yup, we've owned both the 2001 XTO and 2005 Innova diesel and performance is miles apart if you're talking about outright speed and chassis dynamics; it's no fault to the Crosswind, the Innova is just much more newer in design.
    Jan 2011
    #22
    i both owned xwind 05 and innova 06. mabilis at may power ang innova. low torque ang xwind.
    #23
    * vinj's post
    XTO pa yung sakanya ha. Mas magaan yun kaysa sa XUV/XUVi/Sportivo, nababagalan pa siya.
    Yung Crosswind talaga, pang-durability and practicality lang iyan. Pagdating sa speed, tatahimik yan. Max yata niyan is 150kph, sumisigaw na yung makina nun ng " TAMA NA... " while ang Innova kaya pumalo ng 160-170kph with ease. Diesel, of course.
    May 2009
    #24
    Quote Originally Posted by acergy09 View Post
    thnaks for the input bro weisshorn, kaso bagong change oil na ako, bago na na din mga filter...nakadalawang palit nga ako ng fuel filter kasi mahinang klase yung naunang binili ko ng fuel filter...pero sabi nung nagpalit, baka daw palitan yung nasa pic, mahina daw yung pump nya e...any idea bro? ano ba purpose ng nsa picture sa crosswind natin...
    water separator-priming pump assembly....do not replace the pump if it's not broken. the ones available at auto supplies have weaker check valve mechanism, o-rings and spring.
    May 2009
    #25
    no offense meant to isuzu owners but as per experience between a 2.5 isuzu fuego and a 2.4 hilux, the hilux has a better (lower) gearing on the 1st gear on uphill climbing (from a stand still then climb an approximately greater than a 45 deg slope)....still, isuzu is isuzu.
    Jan 2011
    #26
    ^^Dahil siguro bro sa transmission, mas malaki ang clutch assembly ng toyota kesa isuzu, nacompare ko lang sa crosswind at revo Just what I remember before, correct me if I am wrong
    #27
    Quote Originally Posted by shelu View Post
    I 2nd d moshon driven both the xwind and innova... innova will smoke the xwind given the same driver skills and, (this is important) the same driver nerves and balls (of steel if I may say). on a flat highway, xwind will top out at 140-150kph, but it will need a looooooong road to reach this speed. innova tops out at around 160- i'd say 170. at 165kph, lapit na sa redline innova. xwind reaches redline * 145 kph, and it's engine is screaming and screeching out loud. careful when you do these speed tests, requires precision adjustments sa steering and good judgement of road conditions.
    but going back to topic,
    tune up?
    well, aside from the usual change oil/filters (oil, fuel, air)/valve adjustments/change fluids (brake fluid and PS)/aircon cleanup, check your shock absorbers, check your bushings, check your leaf springs (believe me, they can get cracked in due time when you're regularly driving over potholes and rough roads), ball joints, tie-rods, connecting rods, pitman arms, brake pads...and occassionally, check for radiator leaks, and broken exhaust manifolds.
    that's all i can think of... sali mo na rin check or change batteries every 2 - 3 years depending on how well you take care of your batteries.
    Apr 2009
    #28
    Tuwing kelan po ba to pina pa cleaning? kasi po yung akin hindi pa po napapasukan ng tubig.. pero hindi po ako sure kung malinis yung water separator ng hi-lander xtrm ko po.. sabi po kasi sa akin ng ka tropa ko nagkakaroon rin daw sa loob nito ng "SLUDGE" tagal na po kasi hindo ko na checheck yan. Sasabay ko nalang siguro kapag nagpa cleaning ako ng Nozzle Tips at Valve Tapetting...
    Sep 2010
    #29
    yung sa akin bro,wala naman tubig...kaso nung idis assemble nga,ang dumi na ng loob,may sludge na nga sya...parang lumot na kulay brown na bumabara sa valve nya kaya pala ayaw mag pump ng diesel....
    almost 6 years din,bago na dis assemble yan...so matagal din bago magdumi ng husto..
    Sep 2009
    #30
    Quote Originally Posted by sanik View Post
    ask ko lang po, kasama ba sa lilinisin ito during calibration?
    #31
    kelangan ko na din magpa tune up this summer. We went to Fontana then Subic 2 weekends ago gamit sportivo 06 namin, sakay ko family ko(2 adults kami, 1 kid, 1 baby plus mga bags namin). swabe sya umarangkada pero pagdating ng mga 110kph, parang sinisinok na, parang kinukulang ng feed ng krudo or what. pina test ko sa isang driver na kasama namin pumunta, baka daw sa fuel filter lang. di ko kse naitatakbo ng more than 80kph yung Sportivo pag around metro manila lang nagmamaneho ehehe. You think yun lang ang problem nya? balak ko ipa tune up na din, pde ba magpa tune up pero nde change oil(kaka change oil ko lang kse bago kami mag Subic)
    TIA!
    #32
    ^nakapagpa fuel filter change na ako last Black Sat, sinama ko na tune up. Sunday morning, I was able to hit 110kph in EDSA, la naman ako naramdamang drag(hopefully wala na nga hehe).
    went to Dallas T. Morato
    tune up - p700
    fuel filter - 300(bosch)
    adjust/tighten belts - 250
    TOTAL of Php1250
tune up of  crosswind
