Results 1 to 5 of 5
- Jan 2004
- 31
January 3rd, 2004 01:40 PM #1mga sir, first time ko mag pms out of casa and i got a bit confused dun sa oil capacity ng 4jx na engine, ano po ba nag tamang quantity ng oil needed? 7.5 kasi and 10 liters basa ko dun sa manual... parang exag ata? sana po kasi ako sa oto lang which is only 4 liters
any other things i should do aside from having the filter cleaned, check other oils and brake pads? 10K kms ang tinatakbo ng oto.
thanks mga bossing!
- Dec 2002
- 2,335
January 3rd, 2004 04:56 PM #2Kung yun ang nakalagay sa manual then it's the correct qty. Normally 2 quantities are listed, one when you change the oil only and the other when you change the oil and oil filter. Sa 3.1, 4JG2 na engine like mine it's 5 and 6 liters. Iba ang fuel injection syst ng 4Jx1 so possible na 7.5 and 10 L.
You can also consult your owner's manual kung ano pa yung gagawin. It's listed there. Normally clean the air filter, check other fluids like PS fluid, radiator water, brake fluid, etc.
HTH!
January 3rd, 2004 06:26 PM #3
Add mo ang oil pan capacity at oil fiter capacity to get the correct figure.
Then check your dipstick afterwards.
Tsikot Member Rank 3
- Dec 2002
- 636
January 4th, 2004 08:41 AM #44JX1 oil change uses 7.3L to 8L. Have to use thin diesel oil, like 5w30 or 10w30, not a 15w40 oil- otherwise it'll be hard starting, smokey.
Also, use the oem oil filters(both) or Vic C524 for the primary filter. Can't clean the air filter since it's the "viscous type", just replace every 10k km.
May 26th, 2009 08:55 AM #5
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
