Results 1 to 12 of 12
    Mga owners ng crosswind:
    Just would like to ask about the aircon of your ride if you experience the same. I have experienced that the air coming out from the right (passenger side) air vent is weaker compared to the air coming out from the left air vent (driver side). Is that normal? Temp are the same both ar cold, sa hangin lang nag-iba. I have once had this complained to Isuzu Inteco QA, but the service advisor told me that is just normal. Pero para sa akin hindi yon normal. Pa-share naman 'yong experience n'yo. Kung sakaling papaayos ko ito, sa may Isuzu ba or sa Nippon Denso ko na dadalhin? Slmt sa mga magbabasa at sasagot.
    up
    20 vanda 01
    inspect ko muna yon saakin den balikan kita di ko napansin yan.
    baka naman may nakaharang lang or di naka ayos yon tube na daanan ng hangin going out sa air vent.
    May saraduhan ba vents ng Crosswind? Baka sarado. Kung wala have a formal complaint with Isuzu if your AUV is still underwarranty. Factory defect na iyan at baka may nag-bara sa loob. Goodluck.
    Hindi kaya napisa ang air duct while someone was working on your car (installing an alarm, etc.)?
    wala namang close/open valve nung duct para sa passenger air vent. this friday i'll go to isuzu and have this checked. separate ba motor ng fan nito? inisip ko kasi baka mahina ang ikot ng fan kaya mahina hangin.
    jake, ano finding mo sa ride mo?
    Lahat ng dash vents ng Crosswind ay served by a single blower. Either ganyan talaga ang output sa passenger side or may restriction sa plumbing.
    20vanda01
    di ka nag-iisa. matagal ko nang observation yan sa crosswind ko. lately pa nga, nagkaron ng hissing sound sa right/passenger side. sabi ni master boknoyXTRM palpak daw talga service ng Inteco whether QA or balintawak (sa balintawak ako nagpapaservice). ang alam ko Denso sasagot kung aircon ang problema. ewan lang kung sila magkakalas. Palagay ko nga may restriction lang sa ducting kaya ganyan observation natin. so far, I can live with it. di naman masyado malaki difference in cooling efficiency e. pag naka half power na a/c natin, lumalamig din naman sa harap. giniginaw nga si misis e, gusto ko tuloy minsan painitin :mrgreen:
    20vanda01,
    sa akin ok naman mukhang pareho naman silipin mulang yon air duk nya bka may di naka ayos na pagkakalagay.
    rsnald,
    malakas din ba sa water yon xto mo every other day naglalagay ako sa reserve nya napansin ko lang ito nang magchange ako ng oil from shell to delvac mx. magaspang din ang tunog di kagaya sa shell oil medyo pino did you try na mag delvac before?
    ano rin nga pala setup ng sounds mo?
    thanks
    Quote Originally Posted by jake
    20vanda01,
    rsnald,
    thanks
    to jake:
    re: water. try mo checkin yung ride mo while idling if there are leaks from the radiator. nangyari na sa kin yan twice. nung first time, malakas magbawas, like yours. every other day,say w/in 2-3 days halos ubos na yung reserve. i found a leak sa lower part ng radiator. had my radiator replaced since under warranty pa. it turns out that i'm not the only case. meron na rin daw pinalitan ng radiator na crosswind.
    after a few months (9 months to be exact), nagkaron na naman ng leak, pero mahina. when I was requesting them to check, di man lang na check. so I added stop-leak additive sa radiator. yun medyo nawala yung leak.
    sa engine oil naman, I've only tried IGMO (isuzu genuine *kuno* motor oil also known as Castrol ... i saw them loading castrol sa mga oil containers nila). I also tried Petron's Rev-x Trekker. mas ok yung rev-x, mas pino takbo ng makina ko. so sa next change oil ko, i'll try it again. I havent tried Shell or Delvac but i heard shell oil is good.
    re: sounds stock lang ako. di ako mahilig sa abubot pagdating sa sounds e. ok na sakin yung radio at tape lang, no more CD's. istorbo lang sa pagmamaneho e. when I'm on the road, usually nagmamadali naman ako e. saka most of the time, w/in metro manila lang ako. siguro pag madalas ka sa provinces, long road trips, yun maghahanap ka na ng music na bagay sa yo. mahina kasi pickup ng FM sa provinces. swerte mo kung maganda yung local FM radio station. e kung puro intsek FM station mapipik up mo. fatay!
    :wink:
    rsnald
    thanks a lot
    jake
    rsnald i still have it check para naman magkaroon akong peace of mind. although malamig nga ang hanging na lumalabas e kung mahina ang flow ng air, baka ma-trap ang lamig at mag condense sa duct.
    tungkol naman sa radiator leak, minsan nagpaservice ako sa IsuzuQA, dalawa crosswind nakasabay ko nake-claim ng radiator replacement dahil under warranty pa. papalitan naman daw kung magkakaroon na ng stock. so ang ginawa dahil ang leak pala ay dun sa ilalim ng radiator where the hose is connected ay hininang lang. dahil 'yong nakausling tube na to ay nag-crack 'yong pinakadulo where it is connected dun sa radiator. common daw talaga to.
Question on Crosswind A/C
