Results 1 to 10 of 12
November 14th, 2002 02:14 PM #1
Mga owners ng crosswind:
Just would like to ask about the aircon of your ride if you experience the same. I have experienced that the air coming out from the right (passenger side) air vent is weaker compared to the air coming out from the left air vent (driver side). Is that normal? Temp are the same both ar cold, sa hangin lang nag-iba. I have once had this complained to Isuzu Inteco QA, but the service advisor told me that is just normal. Pero para sa akin hindi yon normal. Pa-share naman 'yong experience n'yo. Kung sakaling papaayos ko ito, sa may Isuzu ba or sa Nippon Denso ko na dadalhin? Slmt sa mga magbabasa at sasagot.
November 15th, 2002 10:42 AM #3
20 vanda 01
inspect ko muna yon saakin den balikan kita di ko napansin yan.
baka naman may nakaharang lang or di naka ayos yon tube na daanan ng hangin going out sa air vent.
November 15th, 2002 09:21 PM #4
May saraduhan ba vents ng Crosswind? Baka sarado. Kung wala have a formal complaint with Isuzu if your AUV is still underwarranty. Factory defect na iyan at baka may nag-bara sa loob. Goodluck.
November 16th, 2002 05:41 PM #5
Hindi kaya napisa ang air duct while someone was working on your car (installing an alarm, etc.)?
November 18th, 2002 02:42 PM #6
wala namang close/open valve nung duct para sa passenger air vent. this friday i'll go to isuzu and have this checked. separate ba motor ng fan nito? inisip ko kasi baka mahina ang ikot ng fan kaya mahina hangin.
jake, ano finding mo sa ride mo?
November 18th, 2002 02:44 PM #7
Lahat ng dash vents ng Crosswind ay served by a single blower. Either ganyan talaga ang output sa passenger side or may restriction sa plumbing.
November 18th, 2002 04:21 PM #8
20vanda01
di ka nag-iisa. matagal ko nang observation yan sa crosswind ko. lately pa nga, nagkaron ng hissing sound sa right/passenger side. sabi ni master boknoyXTRM palpak daw talga service ng Inteco whether QA or balintawak (sa balintawak ako nagpapaservice). ang alam ko Denso sasagot kung aircon ang problema. ewan lang kung sila magkakalas. Palagay ko nga may restriction lang sa ducting kaya ganyan observation natin. so far, I can live with it. di naman masyado malaki difference in cooling efficiency e. pag naka half power na a/c natin, lumalamig din naman sa harap. giniginaw nga si misis e, gusto ko tuloy minsan painitin :mrgreen:
November 18th, 2002 05:27 PM #9
20vanda01,
sa akin ok naman mukhang pareho naman silipin mulang yon air duk nya bka may di naka ayos na pagkakalagay.
rsnald,
malakas din ba sa water yon xto mo every other day naglalagay ako sa reserve nya napansin ko lang ito nang magchange ako ng oil from shell to delvac mx. magaspang din ang tunog di kagaya sa shell oil medyo pino did you try na mag delvac before?
ano rin nga pala setup ng sounds mo?
thanks
November 18th, 2002 07:38 PM #10Originally Posted by jake
re: water. try mo checkin yung ride mo while idling if there are leaks from the radiator. nangyari na sa kin yan twice. nung first time, malakas magbawas, like yours. every other day,say w/in 2-3 days halos ubos na yung reserve. i found a leak sa lower part ng radiator. had my radiator replaced since under warranty pa. it turns out that i'm not the only case. meron na rin daw pinalitan ng radiator na crosswind.
after a few months (9 months to be exact), nagkaron na naman ng leak, pero mahina. when I was requesting them to check, di man lang na check. so I added stop-leak additive sa radiator. yun medyo nawala yung leak.
sa engine oil naman, I've only tried IGMO (isuzu genuine *kuno* motor oil also known as Castrol ... i saw them loading castrol sa mga oil containers nila). I also tried Petron's Rev-x Trekker. mas ok yung rev-x, mas pino takbo ng makina ko. so sa next change oil ko, i'll try it again. I havent tried Shell or Delvac but i heard shell oil is good.
re: sounds stock lang ako. di ako mahilig sa abubot pagdating sa sounds e. ok na sakin yung radio at tape lang, no more CD's. istorbo lang sa pagmamaneho e. when I'm on the road, usually nagmamadali naman ako e. saka most of the time, w/in metro manila lang ako. siguro pag madalas ka sa provinces, long road trips, yun maghahanap ka na ng music na bagay sa yo. mahina kasi pickup ng FM sa provinces. swerte mo kung maganda yung local FM radio station. e kung puro intsek FM station mapipik up mo. fatay!
:wink:
New app update for Gcash. It locks the Gcash account to the particular device you are using so you...
National ID Law
