Results 1 to 4 of 4
    Jan 2011
    boss, yung ball joint po kasi ng isuzu sportivo ko is lumuluwa na by the banawenian term. is that needed to be re-bossed or replaced? BTW, are ball joints of cars should be hard or easy to manipulate or turn
    Quote Originally Posted by IOwnIsuzu View Post
    ideally, ball joints are replaced when they get too loose. and good replacements should not hinder movement. hindi siya dapat humigpit. dapat nga ay gumaan..
    now, when the car is so old that ball joint replacements are next to impossible to source, then there are ways to "re-build" them, to make them functional, to extend their useful lifespans.. of course, these irregular machinings, may not result in ideal results. but at least, magagamit pa.
    Aug 2015
    tanong lang po, ung sa akin po xtrm 200, di po nawawala ang kalog ng gulong, bago po ang hab bearing, after a week ganun na uli,kalog, sa ng iba upper and lower ball joit daw, di ba sa spindle yun,do ko kace mapatino ang kalog ng front tire
    Quote Originally Posted by maranan View Post
    ball joints, if busted, should be replaced.... although repair works, but it can only do so for a limited time.
    yung sa kalog ng gulong mo, try to see if the tires are balanced or is not oblong...
question about ball joints?
