Results 21 to 30 of 37
November 3rd, 2013 07:19 PM #21
November 3rd, 2013 10:00 PM #22
[IMG][/IMG]
3 days pa lang gamit ko, napansin ko na may gumagapang ng oil trail galing rocker cover papunta sa filter housing, mga 8 inches ang haba ng oil trail galing sa rocker cover, since medyo paahon yun chemical hose from the cover to the filter housing, i doubt na makakarating yun oil trail sa filter. malamang mga oil mist lang ang maiipon ng occ ko
November 4th, 2013 02:29 PM #23
Dapat puno ng stainless steel wool ang tank para stick and condense agad ang oil mist/vapor coming from valve cover at dahil lquid na siya, mag-settle na lang sa bottom, hindi na sasama sa air papunta sa intake.
Ang PS fluid reservoir na ginamit ko DIY OCC, meron plastic strainer na help filter the oil vapor at ang oil vapor na pass thru this strainer will also come into contact with the Scotch Brite steel wool na inilagay ko sa reservoir, nakaharang sa outlet pipe papunta intake, maiwan ang condensed oil for a clean intake.
- Aug 2009
- 178
November 4th, 2013 03:57 PM #24Do i have to totally fill in my occ with steel wool? Just filled my occ half way.
Sent from my GT-N7100 using Tsikot Car Forums mobile app
November 5th, 2013 01:50 PM #25
- Aug 2009
- 178
November 5th, 2013 09:49 PM #26Thanks sir....
November 6th, 2013 03:58 AM #27
kahit walang steel wool pwede, ang importante na-minimize yung oil na papasok sa pre-turbo. konti lang naman naitutulong niyan kasi even nga may steel wool may nakaka-lusot pa rin na oil bad effect ng may steel wool kapag nalagas yan at ang maliliit na piraso niyan napunta lalo sa manifold yari kaya mo nga nilagyan ng OCC para salain yung oil eh tapos lalagyan mo naman ng steel wool na pwede makadumi lol! si master zix mismo na nagdi-diy niyan ay di naglalagay. more than enough na yung mabawasan yung oil.
and beside, sa mga separator vessels sa oil and gas plants na nainspection ko before kapag may plant shutdowns, ang demister nasa upper part ng vessel bago lumabas sa outlet line hindi lumalangoy yung demister sa liquid..HTHLast edited by monty_GTV; November 6th, 2013 at 04:11 AM.
- Aug 2009
- 178
November 6th, 2013 06:07 AM #28Noted with thanks sir monty....gd am.
November 6th, 2013 06:19 AM #29
Planning to DIY ng OCC, meron na ko steel wool and aluminum can. Saan kaya makaka bili ng fittings para sa hose? AFAIK yung steel wool para pang increase siya ng surface area para mabilis lumamig at mag condense yung gases?
November 6th, 2013 08:08 AM #30
in my case, yun abang ng inlet/outlet ng filter housing is 1/2"NPT , i just buy the necessary GI ang brass fitting that is both 1/2NPT yun thread, and then i just choose the chemical hose which is slightly larger than the OEM rubber hose from the rocker cover. to prevent restricted airflow to the pre turbo, btw, i buy all the necessary fitting, clamps from A hardware store behind the 7/11 store located at the corner of recto and t. mapua st. HTH
Xiaomi E-Car
