Originally Posted by
tomtom
Hi sirs,
I have a TFR and would really appreciate if you can help me with the ff:
1. whenever I turn on the A/C the voltage meter of my battery goes down to middle but when the A/C is off it goes up to 3/4. what seems to be the problem? normal lang yan sir tom...A/C is the biggest electrical consumer on a vehicle (plus the electric cooling fan)...pero sa tinagal ng pickup sa inyo ngayon lang ba nangyari ito?
2. while the A/c is turned on, the idling goes down until the whole vehicle shakes, specially when I am not in motion. What i do to prevent this is I step on the gas pedal....adjust the fast idle control. the diaphragm is connected sa vacuum pump connected at the back of the alternator.
3. while A/c is turned on, there is an obvious decrease in power while stepping on the gas. but it doesn't happen when the A/c is not engaged. is there a problem with the compressor? or is it just normal with the Isuzu 91 model?...related to #1...the magnetic clutch activates to compress the vapor inside the compressor...usually 1-3 hp ang mga A/C compressors. it is normal na maglower down ang power.
Thanks for all your replies. Merry Christmas
