Results 1 to 18 of 18
    Hi sirs,
    I have a TFR and would really appreciate if you can help me with the ff:
    1. whenever I turn on the A/C the voltage meter of my battery goes down to middle but when the A/C is off it goes up to 3/4. what seems to be the problem?
    2. while the A/c is turned on, the idling goes down until the whole vehicle shakes, specially when I am not in motion. What i do to prevent this is I step on the gas pedal.
    3. while A/c is turned on, there is an obvious decrease in power while stepping on the gas. but it doesn't happen when the A/c is not engaged. is there a problem with the compressor? or is it just normal with the Isuzu 91 model?
    Thanks for all your replies. Merry Christmas
    Jun 2007
    whats a TFR sir?
    Kind of pick-up yan bro.
    Isuzu TFR.
    Dec 2010
    idle compensator na naka mount sa gilid ng injection pump. malamang sira na ung diaphragm kase vaccuum operated lang yan.
    Quote Originally Posted by batangtalyer View Post
    sir, so yung diaphragm ang problem dun sa 3 na problem ko related sa A/C and sa idling?
    May 2009
    Quote Originally Posted by tomtom View Post
    Hi sirs,
    1. whenever I turn on the A/C the voltage meter of my battery goes down to middle but when the A/C is off it goes up to 3/4. what seems to be the problem? normal lang yan sir tom...A/C is the biggest electrical consumer on a vehicle (plus the electric cooling fan)...pero sa tinagal ng pickup sa inyo ngayon lang ba nangyari ito?
    2. while the A/c is turned on, the idling goes down until the whole vehicle shakes, specially when I am not in motion. What i do to prevent this is I step on the gas pedal....adjust the fast idle control. the diaphragm is connected sa vacuum pump connected at the back of the alternator.
    3. while A/c is turned on, there is an obvious decrease in power while stepping on the gas. but it doesn't happen when the A/c is not engaged. is there a problem with the compressor? or is it just normal with the Isuzu 91 model?...related to #1...the magnetic clutch activates to compress the vapor inside the compressor...usually 1-3 hp ang mga A/C compressors. it is normal na maglower down ang power.
    maligayang pasko rin sir
    Quote Originally Posted by miked View Post
    ngayon lang sir nangyari sa akin yung problem #1. may nagsasabi kaya daw bumababa yung idling kasi sira daw yung "idler's up". any comments on this po? thanks
    Feb 2005
    You mean IDLE UP. Could be. First I read your post made me want to suggest you to check that but I thought there may be other issues that may have contributed to it. Either way, it would not harm to have that one checked too.
    Sep 2008
    For this question
    whats a TFR sir?
    Answer:
    http://tinyurl.com/337ne5w
    Regarding problem number 1, Okay pa po ba yung alternator nung tfr niyo sir?
    Quote Originally Posted by Benzmizer View Post
    thanks sir
    Hi sirs,
    Umiilaw ba yung charge light when ever you turn on the AC?
    Umiikot ba yung aux fan (normal speed/grounded sound)?
    Check if the line of the AC wires and solenoid valve of the Injection pump are touching or share the same ground.
    If the idling goes down certainly the charging will be affected. You just have to know if the AC is the cause or the victim.
    Feb 2010
    sir, i also have TFR and have encounter that same problem, first have your alternator check, Vaccum actuator and idler up. my situation kasi na dala lang sa pagadjust hope yours too..
    Quote Originally Posted by erikyu View Post
    sana nga sir para iwas gastos
    Quote Originally Posted by 4JGtootsie View Post
    sir, ano po yung charge light ng AC? saan po yun makikita? from the time i had my pick-up 2 years ago wala naman po umiilaw when I turn on the AC. Ngayon ko lang ito na-experience.
    isa lang naman sir ang aux fan ng isuzu TFR hindi po ba?
    Charge light is connected to the alternator and cluster/voltage gauge. kung grounded or open line its suppose to light up.
    Yes isa and usually turns on when AC is also on but kung grounded it affects electric flow to other wires and electrical components.
    SO far adjustments lang po sa idle up ang problem. Ok naman po ang alternator at kumakarga naman. Next problem to solve na lang yung accelerator cable.
    Feb 2011
    hmmm... bakit yung sa isuzu fuego ko eh baligtad yung nangyayari compare sayo... pag binubuksan ko na yung AC eh tumataas na yung menor?
Need Help with Pick up problems
