Results 11 to 15 of 15
July 10th, 2009 10:31 PM #11
yes sir nakita ko nga na may code pa original, try ko din pumunta sa casa para mag pa duplicate.
thanks Benzmizer.
*sboogie thanks sir.
ura mismo nong nag pa gawa ako binalik ko agad refundable naman.
bow ako sa tsikoteers!!!!!!!!!
July 10th, 2009 11:04 PM #12
*Col_em: In behalf of those who posted to try and help you, you're most welcome. We (including you) are enthusiasts here.... helping others and helped by others.
July 10th, 2009 11:47 PM #13
sir pwede ba mapaiba ng konti? tungkol pala sa headlight ko 55w/ lang yata, (pag na ulan at may kasalubong ako parang bulag kong baga.)at may kalumaan na gusto ko sana palitan ano kaya pwedeng wattage? balak ko sana all weather? kailangan pa ba mag palit ng mga wirings if ever mataas na wattage ilagay dito? shops nearby cavite or las pinas for this headlights. TIA>>>>
July 11th, 2009 01:38 AM #14
Of course you can upgrade the wattage. Make it 90/100 all weather type. But I's suggest that you use thicker gauge wires to accomodate the added electricity passing thru it (lalo na may edad na oto mo) and put a relay for EACH headlamp.
I'm not so familiar with the reputable shops thre in Cavite but surely there are. Dyan nakalunga yung mga matitinik mag-oto e.. Hehehe!
March 16th, 2010 07:35 PM #15
update ko lang...
okey na duplicate key ko may konting himas lang pala....
salamat sa lahat na nag reply.......
baka pwede na ma DELETE ang thread na ito!!!
high idle RPM at engine start
