Results 11 to 17 of 17
- Nov 2004
- 26
December 6th, 2004 04:52 AM #11ah ok. maingay na nga yung makina ng crosswind iingay pa lalo. mahal pa yung delvac. salamat pare. noted na lahat ng inyong suggestions. God bless sa inyo.
- Sep 2009
- 29
September 2nd, 2009 06:10 PM #12I have crosswind xt 2005 model. Second hand namin ito nabili kaso ate ko ang madalas gumamit at nag me maintain. alaga sa change oil every 5000 kms. 4ja1 po yung makina. Due na daw ito for change oil sabi ng ate ko kaso sabi nya, 5.5 liters daw ang ilalagay. Ano po ba talaga tamang sukat ng langis? Pwede ba i DIY ko na lang ito at bibili na lang ako ng motor oil sa ace hardware? Sana matulungan nyo po ako. Thank you.
- Aug 2009
- 24
October 17th, 2009 04:23 AM #13
- Oct 2009
- 19
October 17th, 2009 08:02 PM #14helo guys! i have xuv 02 model a/t turbo engine, they change oil dapat 6 LITERS daw ang gamitin ko or bilhin?! tama ba yung amount ng liters ko or sobra sa makina??? I used petron s semisynthitic. ok naman cya...
October 19th, 2009 11:24 AM #15
nag pa change oil ako last week sa kilalang mekaniko. i use CASTROL CRB. at first i only bought a gallon which equivalents to 4 liters. nung nilagay ng mekaniko sabi nya bili pa raw ako ng 1 liter pa kasi parang kulang pa raw (he used the dip stick for basis).
di ko na magawang itanong kung bakit kailangan pa kasi nahiya ako matanda at respetado rin kasi yung mekaniko dito samin parang sino ba naman ako. but according to my ride's former owner he only uses 4 liters of oil for my XTO kaya yun lang ang naunang nabili ko.
nung kinarga na yung isang litro and test drived my ride, nung binuksan ko yung hood for inspection napansin ko may parang tapon ng mga langis sa makina parang galing sa cap ng makina kung san nilalagay yung langis. pinunasan ko yung mga tapon, thinking it was just an accidental spill when the mechanic poured oil.
after a few bumpy drives and inspecting whats under my hood again, yun ulit ang nakita ko pero after a couple of drives, sa ngayon parang kaunti na lang.
-mga boss, nasobrahan kaya ng lagay sa oil kaya may "spills" akong nakikita sa engine?
-at masama ba ang maraming langis na ikinakarga sa makina?
so far parang wala namang nagbago sa performance at takbo ng ride ko except dun sa mga kaunting "spills" sa engine.
TIA!
- Apr 2009
- 544
October 22nd, 2009 01:10 PM #17mine is xto. changed oil many times already and 4 liters lang. baka yung mechanic sanay sa mitsu L300 na 5 liters.
masama talaga ang sobra. ang pagkaalam ko it will go somewhere and eventually damage your engine. kasi yan ang sinabi sa akin ng isang mechanic nung nag umpisa pa langa ko mag drive many years back.
same as gear oil and transmission pag sobra mag foam siya and will greatly affect the performance of the parts.
better tingnan mo dipstick if its not running for a long time. should not exceed the max level
Xiaomi E-Car
