Results 1 to 10 of 17
- Nov 2004
- 26
December 2nd, 2004 03:21 AM #1mga tsikoteers tanong ko lang po kung anong motor oil ang gamit ng casa ng isuzu sa crosswind xuvi at ilang litro po? balak ko po kasing i DIY yung change oil ng crosswind namin. e sabi po kasi sa casa na "stick to one brand of oil". daw po kasi. maganda din po kaya yung mobil delvac para sa 4JA1? maraming salamat po ule sa inyo.:bald:
December 2nd, 2004 09:58 AM #2
Crosswind uses around 5L.
We don't listen to the CASA's "use only Isuzu oil"... :P Right now we're using the Petron Trekker (15W-40, API CH-4 rated). In the next oil change we'll be putting Caltex Delo Sport semi-synth.
Mobil Delvac is ok but i'd still suggest that you continue to change your oil every 5,000km even if you're using synthetic oil. Thus if you're on a budget, sticking to mineral or semi-synth will still do very well (what matters is you follow the oil change interval).
BANNED BANNED BANNED
- 126
December 2nd, 2004 10:09 AM #3I personally use the fully synthetic of Petron on my Patrol. I think it's 5W or 10W-30.
Personally, also, I don't believe that the 30 SAE weight is too "malabnaw". My Patrol is 11 years old, and there really is no problem.
They say that if the viscosity is too light (malabnaw) it cannot protect the engine well or something like that. With the newer formulations, I think (again, my opinion and experience only) that there is no problem regarding this.
The advantage of a lighter viscosity oil is less friction and therefore slightly more power / better fuel consumption.
The disadvantage with too light a viscosity is that if you have an older car and the o-rings/gaskets/etc are not up to snuff, the lighter oil might seep out.
I personally change every 10k (but change oil filter every 5k and then just top off). Eh, kasi, Patrol ko 9-10 liters of oil, eh. Dalawa pa nga oil filter. I also add LiquiMoly additive (1/2 liter) every oil change.
I also don't believe that you should only use Isuzu oil... they're just selling.
December 2nd, 2004 12:02 PM #4
if you're tight on budget use mineral or semi-snthetic oil. just follow the recommended viscosity and API rating in your manual.
otherwise go for the full synthetic.
- Nov 2004
- 26
December 2nd, 2004 04:56 PM #5thanks vinj, alfalfa, ram. maraming salamat sa inyo. siguro semi synthetic na lang gamitin ko. mahal yung delvac. yup tama nga siguro kayo. sinasabi lang nila na dapat "isuzu oil" para makabenta din sila. kainis kasi sa casa, change oil lang, maghapon mong iintayin.
alfalfa...dalawa pala oil filter ng patrol! ngayon ko lang nalaman yun ah.
December 2nd, 2004 05:41 PM #6
*palku
habol ko lang.. xto driver here.. 90,000+km so far
i've used the following oils
IGMO (Isuzu genuine motor oil)
Petron Rev-x Trekker
Shell Helix Diesel
Shell Helix
Caltex Delo gold monograde
Caltex Delo gold multigrade
Castrol GTX Diesel
Castrol CRD
the best so far, Caltex delo gold multigrade and Petron Rev-X Trekker.
4 to 4.5 liters lang nagagamit ko. hth ;)
- Nov 2004
- 26
December 3rd, 2004 08:09 AM #7Originally posted by rsnald
*palku
Shell Helix Diesel
Shell Helix
Castrol GTX Diesel
Castrol CRD
4 to 4.5 liters lang nagagamit ko. hth ;)sige 4.5 liters lang.
December 3rd, 2004 11:25 PM #8Originally posted by Palku
i used shell super dzl 4 litersLast edited by x-wind; December 3rd, 2004 at 11:30 PM.
- Nov 2004
- 26
December 4th, 2004 08:11 AM #9Originally posted by x-wind
before the change oil try mo pakingan yun makina then after chage oil with delvac you can see the difference........... baka after 1 week magpalit ka na kaagad ng oil..................
December 5th, 2004 07:30 PM #10Originally posted by Palku
x-wind bakit after 1 week magpapalit na agad ako ng oil kapag delvac ginamit ko? enlighten mo naman ako. thanks
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
