Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Feb 2017
    Isuzu hilander 97 model
    Newbie ako sa sasakyan kya ask ko po kng anu problema.
    Nagpalit ako ng ilaw yung signal light n orange,nagkamli ako ng kabit,nashorted sya,
    Ayaw na umilaw ng tail light at dashboard saka radio at clock wala n,kya hnd ko mgamit sa gabi pero yung head light nya ok,
    Ncheck ko n fuse san b bnda ang iba png fuse nito bikod sa baba ng drivee side,
    Hnd ko mkita kng saan busted.
    Salamt sa mkakatulog
    Quote Originally Posted by A R N E L View Post
    if you can get a hold of an owner's manual.
    usually, the manual has a diagram of the fuses and what appliances they control.
    the combination of non-functionals above, suggests one or two fuses, that the manual should be able to point out.
    a number of cars have two sets of fuseboxes. one in the engine bay, and another hiding under the dashboard.
    if owner is lucky, the fusebox cover has enough diagrams to indicate which fuse is which.
    otherwise, one will have to look for these diagrams.... from manuals or from internet downloads.
    Feb 2017
    Ok namn lhat ng fuse sa baba ng icheck ko. Tnester ko dn ok nman,my ibng fuse n nka jumper nga pero good nmn,ang hnd ko p ntiting yung likod ng fuse box hrap kasi baklasin kasi bgo plng sa akin yung sasakyan second hand nmin nbili kya wala sa akin yung manual
    Feb 2017
    Up ko lng po ito,san ba ang location ng isuzu hilander ang relay at fuse box bukod sa baba ng driver side?
    Salamat.
    Salamat.
    i don't have one.
    so, if no one volunteers info, you might want to try googling it, sir.
    it'll be a chore, but if no one answers you here, that might be your only choice.
    save for the casa.
    Feb 2017
    i don't have one.
    save for the casa.
    Nahalungkot ko na ang buong google wala ako makita,nakapagdownload n dn ako ng manaul ng isuzu pero iba ang position ng fuse at relay nya.
    Nagbabakasakali lang ako dto n baka may makapagbigay ng idea para ako nkang ang gumawa.
    Tnx.
    Jul 2013
    I suggest that you just replace the fuse... (kahit sabi ng tester gumagana).
    Feb 2017
    Salamat sa suggestion mo sir,yun lang muna ang una kng ggawin habng hnd ko pa nkikita yung relay at fuse box.
    Mar 2005
    may relay para sa park/panel lights sa bandang driver's side lower panel or cover. kasama sa panel/cover yung takip ng fuse holder, speaker grill at aircon vent.
    pag tinanggal mo yung panel, may speaker dun. tanggalin mo yung speaker, naka screw lang un.
    dun sa butas, makikita mo dalawang relay.
    yung 2nd relay para sa park/panel lights. yung 1st para ata sa fog lamps.
    naka clip un relay kaya ingat sa pagtanggal.
    Mar 2005
    Salamat.
    sa bandang lower left at right ng dashboard. or bandang magkabilang gilid meron mga relays.
mga sir/boss help sa isuzu hilander ko,nashorted ang wiring
