Page 29 of 73 FirstFirst ... 1925262728293031323339 ... LastLast
Results 561 to 580 of 1445
    #561
    Hi guys. I just had my major PMS last week.
    Change oil. Royal Purple 5w-30. (shell helix diesel 15w-40 for flushing)
    Transtech for the A/T. We used 11 liters of RP atf.
    Replaced the two oil filters and fuel filter. All genuine isuzu.
    New antenna assesmbly and db drive amp.
    Ubos ang budget.
    Feb 2005
    #562
    Quote Originally Posted by s_quilicot View Post
    Ubos ang budget.
    Ayos yan, SQ! Sarap i-byahe nyan!
    #563
    Quote Originally Posted by Benzmizer View Post
    Yup sir benz!
    new wheel balancing and alignment (caster and camber).
    New brake pads. (4 pairs)
    New RP 75w-90 axle oil
    New brake fluid.
    I just bought a K&N recharger kit for the air filter. Tinatamad pa ako linisin.
    coming: new wiper. Hehehe
    I love this year. Lahat bago.
    Aug 2009
    #564
    Ubos ang budget.
    where do you buy your Isuzu Parts other than sa CASA
    Good Evening Sir.
    saan ka ba nagpa change oil? where do you the transtech for the A/T? oil filter and fuel filter, where do you buy
    new antenna ang assembly - Our antenna is not going up. probably stock up. what shop did you let your antenna be fix/
    How much is the budget? Do you have any idea, where can i buy ISUZU Compressor? recommended shop? thanx
    Aug 2010
    #565
    Baka may bad ground ka kaya mabilis drain ng battery mo -- not necessarily malakas kumain ng kuryente alarm mo dati.
    As to where to have a grounding kit, any reputable car accessory shop would do.
    --will have it check nalang.
    #566
    Yup sir benz!
    New brake fluid.
    Sarap buhay!
    Puro bago ang Trooper mo ah. Well maintained! haha
    #567
    Quote Originally Posted by migueljiego View Post
    baka po me alam sa inyo san po ako makakakuha ng murang right fender ng 02 na trooper,thanks.....eto po pala contact number ko po 09209203245
    I saw a couple of those lying around in Capalang, pampanga. they where cheaper than my hi-lander's fender (P2500 ea.) a few years ago because they where newer daw.
    #568
    nagpunta na po ako dun eh,wala na po makuha,pati headlight ko napilitan na ko sa casa kasi wala makuha eh yun fender makakapaghintay pa naman kaya abang abang muna baka me makuha mura,tnx po....
    #569
    Quote Originally Posted by baby_scar View Post
    Good Evening Sir.
    Hi sir!
    Nagpapa change oil ako sa Speedyfix since early 2008. I use Royale Purple 5w-30 fully synthetic * 550 php per quart. around 7.5 liters yata magagamit.
    Transtech- sa Speedyfix din. We used 11 liters of RP Atf. Around 11k din.
    Kailangan mo ng ATF filter per wala ako mahanap!
    2 oil and 1 fuel filter- I bought a genuine isuzu filter sa Walco banawe. 800php yung malaking oil filter and 400php naman yung maliit. 2K+ ata yung fuel filter. I forgot.
    Sa antenna naman I bought a rod assembly sa walco for 1.7K pero Sira na pala buong assembly ko including the motor. Costs around 5.5K sa walco pero opted na sa maspro banawe nalang magpakabit. We used a universal power antenna assembly. cost me 1.8k lang.
    I still have the brand new rod assembly for the trooper. I'll give it nalang kung sino may kailangan sa EB.
    So in total mga almost 50k nagastos ko.
    Not including the Timing belt na ang mahal sa casa! I replaced my drive/fan belt din pala with BANDO brand. 500php sa speedyfix. (750 yung sukat ng belt for the Ac compressor ng trooper.)
    HTH.
    Sep 2005
    #570
    Paps patulong naman san pwede makakuha ng end-cover for my troopers stepboard
    Jun 2010
    #571
    [quote=al00399;1560398]Paps patulong naman san pwede makakuha ng end-cover for my troopers stepboard
    [/quote
    pareho lang ba ang left and right end stepboard? ano ba kailangan mo? I think i have 1 extra, will check pre
    Sep 2005
    #572
    nice! thanks sir phantomsx88. Left front side ung nawala saken sana un ung extra mo
    Jun 2010
    #573
    Quote Originally Posted by al00399 View Post
    sorry bro, right front pala un extra ko when i checked it
    Sep 2005
    #574
    nyayk, sayang baka ung ibang experts naten meron natatago na spare
    #575
    Right rear side naman yung nawawala sa akin. Sumayad ata sa gutter
    Napansin ko kasi tabingi din step board, parang pumasok..
    Apr 2008
    #576
    Hay... Ang baba naman kasi ng stepboard ng Trooper. Laki ng binawas sa ground clearance! Mas steep lang ng konti yung parking ramp jan may maririnig kaagad na CRUNCH!
    Apr 2008
    #577
    Just curious, would you be able to fit the stock Trooper rims in 265/70/R16 tires? By the time it is time to change tires, I wish to look for bigger tires with a higher speed rating (preferably H).
    Feb 2005
    #578
    Quote Originally Posted by GTi View Post
    Yes..... without issues. Personally, I like it and it looks better.
    Apr 2008
    #579
    I see, any particular brand/model which is better? I am really thinking of H-rated tires since the speed limit of S-rated tires is really low, I wouldn't want my tires to blow up when I'm running at speeds over 180km/h.
    Feb 2005
    #580
    Bridgestone and Yokohama comes to mine. I am unsure if it'll be a plus to you but I believe both comes with white lettings.
Isuzu Trooper discussion
