Results 1 to 10 of 840
- May 2004
- 903
August 8th, 2007 01:36 PM #1Pwede ba eto:
Post kayo parts and prices for our isuzu rides
Post ninyo din kung saan nabili.
Heres my initial list
Pang Hilander
SHop is Walco banawe
Oil Filter Vic ----- Php200---- OEM Brand Php150
Air Filter Original ---Php650
Fuel Filter Vic -----Php180
Door Hinge front ---Php850 upper---Php450 Lower
Window trim(Yung Kinakalawang) Replacement ---Php380 each
Shock Absorber front KYB---Php850 Gas type---KYB---Php750 Fluid type
Tail Light Taiwan---Php650 each
Tail Light Chrome na Bilog---Php1500 set
Front Grill Hilander Chrome Replacement---Php1500Last edited by 1997; August 8th, 2007 at 01:49 PM.
August 8th, 2007 02:51 PM #2
Offer ko sayo yung Hankuk brand na Shock Absorbers Made in Korea for your Hilander for only P650 each front and rear, fluid type.
I also have affordable suspension parts for Hilander. The brand is Atlas Made in Thailand. Balljoint Upper P420 each; Balljoint Lower P480 each; Rack End P350 each; Tie Rod End P415 each. Suspension parts are guaranteed and tested.
Just txt me at 09177448113 if your interested and to order the parts. You can pick up the parts here at Makati Cinema Square Mcdonalds.
Thank you.
Jay C.
09177448113
FrankDrebin Guest
August 8th, 2007 03:42 PM #4
FrankDrebin GuestSeptember 19th, 2007 03:39 PM #5
Any recommended shop for replacing a Door Hinge for a Highlander? Kailangan pa bang i-repaint? Thanks!
September 27th, 2007 10:55 AM #6
Hi I'm new here and I have an Isuzu 1999 trooper with a 4JX1 engine. Nabasa ko from the previous thread na problemihan talaga yung ganitong engine.
Para maiwasan ano kaya ang the best na pwedeng gamitin parts, saan the best bumili and the best service for a trooper na ganitong (hinde ko pa kayang mag casa medyo mahal)
Air filter?
Oil filter?
Fuel filter?
timing belt?
Engine oil?
spark plugs?
Medyo first time kong mag maintain ng tsikot kaya medyo lost ako. I need help big time
September 27th, 2007 11:31 AM #7
- Oct 2007
- 1
October 6th, 2007 05:31 PM #82004 Crosswind Tail Lights (original, crystal) - 4k
2006 Sportivo Tail Lights (original, yung white ang bilog) - 4k
2004 Crosswind Clearance Lights (original) - 3.5k
By order, through a friend.Last edited by wgumabay; October 6th, 2007 at 05:33 PM. Reason: clarification
October 14th, 2007 08:59 AM #9
magkano yong side mirror with LED signal light? busted kasi yong mga LED sa Left side mirror ko. Ride: 2005 crosswind xuvi.
- Nov 2007
- 50
November 22nd, 2007 04:35 PM #10Mga bro,
if you are looking for parts for our beloved isuzu machines and others,, try nyu
BLAZER CAR MARKETING
pinakamura sa banawe. sa KITANLAD st. kahilera ng NISSAN YEN..
look for Robert.. promise dyan kumukuha iba runners and other auto supply sa paligid.
ALWAYS ASK FOR THEIR LESS 15 PERCENT
How true will this shake-up be? Only time will tell. Drivers licensing to be overhauled | The...
