Originally Posted by docrjay
subukan mong tumingin sa mga bangko ng mga nabatak...it wud help kung may kakilala ka.![]()
tyaga tyaga ka lang mag-search sa buy & sell. it will pay off.Originally Posted by docrjay
BTW guys, sinalbahe yata yung left side mirror ko...parang tinulak ng malakas papunta sa harap..umangat/mukang may nabali sa mechanism..yung mga ball bearings nawala sa pwesto..its the motorized type..i took the car at isuzu pasig..they said they cannot/or dont repair those types problems and that the replacement wud cost around 13k! Jesus! unbelievable!
now the problem is i dont think i can afford that..the motor controlling the mirror itself is still working properly...meron ba kayong alam gumagawa nito o merong nabibiling medyo mas resonable ang presyo kasama installation?
naisip ko nga i-epoxy ko nalang... yun nga lang di na matitiklop.
pls pardon me...bat merong mga taong wala talagang magawang mabuti.. :mad: yung revo ng kapitbahay namin inihian sa rear door at ginasgasan pa..we park on the same lot.
baklasin mo muna baka natangal lang yun lock nung spring sa loobOriginally Posted by nerbyoso
1. first open door sidings and disconnect electrical connection
2. second may 4 pcs or 3 na screw sa loob ng door kalasin mo then saka mo matangal yun side mirror
3. try mo dahandahan tangalin yun naka clip sa salamin para matangal mo sya (inagt lang baka mabasag salamin)
4. then mababaklas mo na yun sa loob dun makikita mo tangal yun lock nung spring.
try ko post yun pic hanapin ko lang
diy pwede yan gud luk
Originally Posted by x-wind
x-wind, thanks a lot bro..you've been very helpful..pls do post the pic...hindi ko kasi kabisado mechanism nito...they dont want to do it, i'll do it...i'll wait for the pic anyway di ko rin magagawa ngayon kasi nasa isuzu pasig yung auto for paint job...january na daw makukuha.
pabaklas mo yun side mirror or ask mo natatangalin mo para ma repair mo na.
hope this pic can help
pic 1a after matangal yunglass ( white nanakikita mo yan yun pang dikit sa glass kaunting ingat lang matatangal mo yan pag balik mo pwede pang gamitin yun )
pic 2a after matangal yun center screw ( tangal dito yun plate na holder ng glass)
pic 3a after matangal yun mechanism malamang yan sayo tangal yun lock nung spring tyaga lang mahirap mag balik nung lock pag nakalagay na yun spring
may bulitas din yan dalawa or tatlo sana nandun pa
pero diy kaya yan
x-wind, wow! where did you get these pics?! mukang crosswind side mirror talaga yan ah...nakikita ko nga yang "swivel shaft" na yan pag inaangat ko but i can pull it up more than an inch lang siguro dahil duon sa electrical cable...the bb's are still there..mga tatlo yata nakita ko.
you mean that white stuff is the only thing thats holding the mirror? what is the best tool in removing it? can i use a knife or a screw driver? pwede kaya initin to remove it more easily? i think thats the most tricky part eh.
it happen also on my unit kaya nabinaklas ko side mirror ko.
white stuff and yun sa edge nung glass parang naka clip all over sa glass. sa akin kasi pinuwersa ko so ang natangal yun holder ng glass saka ko lang na nadiscover na pwede tangalin yun glass first para di mahirapan. kung may kakilala ka sa banawe na sungkit boys ng side mirror baka kaya nila (joke only)
ingat lang bro
mga bro...ask ko lang bakit di ko mabuksan yung mga jpeg files. Need your help. Nag loose din kasi yung side mirror ko. Salamat in advance.
Patulong naman po. Natanggal yung lock nung spring ng side mirror ko. nahuhugot na tuloy yung buong assembly nung side mirror from pivot. Di ko mabuksan yung photos kung paano kalasin.
i'll do that sir...i will get back and post whatever will be the outcome..thank you very much again...
muka ngang mahirap-hirap ibalik yung lock...mataba at matigas yung spring.
*nerbyoso
...oo nga..ingat ka dude... ako sinubok ko din kalasin side mirror ko dahil natanggal yung malaking spring, ayun, nabasag tuloy yung glass habang tinatanggal at nung binabalik ko na sya.ang $$mahal$$ pa naman ng lintek na sidemirror na yan!
mahirap ibalik yung spring mechanism kung di ka gagamit ng vise-grip. yun lang nagawang paraan in my case kaya naibalik namin. lagyan mo din ng grasa yung bearings pag binalik mo na unit yung side mirror holder.
rsnald san ka nakabili n glass and how muchOriginally Posted by rsnald
rsnald,
bwahahaha!..kala ko ako lang nakabasag..kala ko nga matatangal ko ng maayos biglang tick! basag!am not sure but i guess the error i made was that i underestimated the strenght of that white stuff..di sya pwedeng biglain..dapat yata meron kang manipis and flexible na knife pang slice dun to remove its hold dun sa likod ng mirror...much like yung ginagamit sa buko ng nyog..still i cud be wrong.
pero ok lang alam ko na kasi na malaking porsyento na mababasag ko..bukod sa explicit warnings ni x-wind i also read between the lines.
pero naayos ko yung spring..ginamitan ko lang ng open wrench na tamang laki patulong ako sa bayaw ko na hawakan..i hit it as hard as i cud ... alam ko mag re-recoil yung spring kung di malakas..gumakat naman tapos pinukpok ko uli hangang sigurado na akong seated na yung lock properly.
yup, nilagyan ko ng grasa yung BB..ginamitan ko rin ng steel spoxy to fill yung kinain na uka ng BB nung mapwersa sya.
mga tanong:
1. saan ako makakabili ng replacement mirror and that white sticky stuff? how much?
2. naputol ko yung one of the two "flathead fasteners" (ano bang tamang tawag duon?) yung naka expose yung ulo sa forward area ng door siding..san ako makakakuha ng replacement nyan.
thanks in advance.
welcome to da club nerbyoso :D, ganun din experience ko... isang inosenteng *tick*... ayun basag na yung glass. yung white sticky stuff, parang white sealant na ginagamit sa mga transparent na salamin sa window panels. meron nabibili nun sa Ace hardware, yung naka-tube, merong conical nozzle. Kelangan mo din yung sealant gun to squeeze it out. Pwede din yung nasa parang tube ng toothpaste, mamili ka na lang dun. Pero kung ako sa yo' ipunin mo na lang yung dating glue. Pwede pa yun.
replacement mirror? sabi ni x-wind, ihahanap nya daw tayo ng mabibilhan![]()
as of now... casa lang talaga, pero P13thou yung buong assembly and they won't sell the glass mirror only! buset na casa.
yung flathead screw, subukan mo magtanong sa mga automotive shops. dalhin mo lang yung orig na bolt/screw para matched yung threading ng screw.
screw sa bolt and nuts sa stronghold sa pasay before rotonda
thanks x-wind and rsnald.
nope its not actually a screw eh..yun bang plastic na sinusuot dun sa mga butas para dumikit yung sidings...dalawa lang kasi duon sa pinto yung visible the rest nakatago..yung isa sa mga visible ang naputol eh..grey rin ang color nya to match the plastic siding.
my bro-in-law mentioned about a place called kapalangan..boundery daw yun ng bulacan and nueva ecija..baka daw meron dun mirror...meron na ba nakapunta dito...problem is i heard stories about this place.
ah..yun pala. may nakita akong sa Concord auto shop, meron sila nyan. ang problema, di ko maalala kung anong branch ng Concord ko nakitaOriginally Posted by nerbyoso
kung SM Mega, SM City West Ave or SM fairview hehehe...lahat kasi yun may branch ng Concord. basta one of those 3 branches have it. or you can try asking sa mga auto supplies shops.
on the side mirror replacement... balitaan mo din ako pag may nakita. ;)
