Results 161 to 170 of 640
- Aug 2008
- 20
February 26th, 2009 06:04 PM #162yup tama si sir s_quilicot..35 watts lang yung HID namin..hindi naman ganun kalakas sa kuryente pero malakas ang buga ng ilaw..just installed the other day sa 06 escape, headlights and fog lights chaka sa 92 BMW 525i, headlights only, to follow pa yung fog lights kasi out of stock..and will be installing sa 1997 S class mercedez benz..
i checked sa mga malls kung how much yung HID nila..its a freaking P8000 sa single beam, tapos P10000 for the telescopic (both hi and low are HID)
March 7th, 2009 11:55 AM #163
- Aug 2008
- 20
March 8th, 2009 07:49 AM #164sir 5k/set lang po..may installer po akong makukuha, P500/set ang labor..
update lang po re my site..you can check my HID's and other items *
www.carstuffs.multiply.com
bagong gawa ko lang po yan na site..u can post ur orders there or inquire directly thru text or call..09209184276 / 09275000571..look for me, RON..
thanks..
- Aug 2008
- 20
March 8th, 2009 11:06 PM #165good pm mga crosswinders,
anyone interested in buying XENON Lightning HID Lamps?
H4 5000/set for single beam (with ballast) only..
H4 7000/set for hi & low HID (with ballast) only..
i also have H3 HID for fog lamps..
i also have different HID's for different types of cars..
i installed H4 & H3 8000 Kelvin in my XUVi just yesterday..pls click the attached link for the pics..sensya na medyo pangit ung cam na nagamit ko..
i also have different color temperature ranging from 3000-14000 Kelvin..
just text or call me if you have inquiries at 09209184276 or 09275000571..look for RON
here is my new link..www.carstuffs.multiply.com
- Aug 2008
- 20
March 8th, 2009 11:07 PM #166good pm mga crosswinders,
anyone interested in buying/installing XENON Lightning HID Lamps?
i installed H4 (headlight) & H3 (foglight) 8000 Kelvin in my XUVi..pls click the attached link for the pics..sensya na medyo pangit ung cam na nagamit ko..
March 9th, 2009 12:02 AM #167
March 9th, 2009 06:21 AM #168
Hi, i'm not a Crosswind owner but i regularly drive one because it's my GF's ride. Since we're planning to live together soon, i may have to be the one to take care of her '04 XUV. I'm not a car newbie but this would be the first time for me to take care of a diesel engine since all of my cars were gas powered. What are the critical components that must be regularly checked which is specific to diesel? I know for a fact the Isuzu diesel's good reputation back in the old isuzu powered Gemini cabs that could operate regularly for three years without any major engine repair/overhaul!
Does this still hold true for the current Isuzu diesels? My gf's XUV is very reliable, in the four years i've driven it, only a starter issue happened as far as i could remember. Probably because her dad takes good care of it. I've gotten accustomed to the vibration and the noise which was really annoying at first. The clutch feels a bit rough when you press it, as if there were fine sand on the clutch oil. (i'm not even sure if its fluid or cable to start with... haha..) About speed... we'll i'm not expecting much but at 120 kph, you know that it's struggling to keep up if you force it. You just have to let it relax and accelerate at its own time. Hope you could give me more maintenance tips for the XUV. Thanks.
March 11th, 2009 06:13 AM #169
March 11th, 2009 06:22 AM #170
for the maintenance of the crosswind..
I suggest you change oil every 5000 kilometers. if doing outside the casa. be sure to use the right engine oils, ATF, fuel filter, and regular check up of the belts. This is very inportant specially for the transmission oil.for the AC every 6 months is recommended. check brakes every 2 years. Hope this helps.
Still atop & adored. The 221 Mazda MX-5 is Still On Top, According to Consumer Reports Sent...
2016 Mazda MX-5 Miata
