Results 631 to 640 of 640
- Dec 2010
- 3
August 22nd, 2015 12:33 PM #631mga boss tanong ko lang po sana. yong A/C ko medyo mahina na at meron daw leak sa hose. Sabi ng nasa shop dapat daw putulin ang hose at ang base nya. yong aluminum na nag hold sa hose. tapos papalitan daw at i-solder. Wala daw set para dito. Tama ba?
Another thing, may connection ba yong problem sa madaling pagka ubos ng coolant ko sa radiator sa A/C problem ko or completely separate issue?
TIA sa mga mag reply.
- Nov 2009
- 27
September 14th, 2015 07:41 PM #632Mga sir tanong ko lang kung san banda nakalagay ang idle up switch ng crosswind XUV? Mlakas ang alog ng makina pag nag engage ang thermostat. Kakapalit ko lang ng engine support at transmission support. Pag enganged thermostat hindi tumataas ang rpm. TIA
- Sep 2015
- 1
September 18th, 2015 02:21 PM #633Meron na po ba dito na ngDIY ng mesh grille for 2002-03 model xuv-i crosswind? Or Meron ngbbenta na mesh grille?
- Jun 2017
- 4
June 30th, 2017 07:39 AM #634May obd2/euobd port ba ang 2003 crosswind xuv? magkano kaya paayos ng speedometer? thanks
- Jul 2009
- 2,618
July 1st, 2017 12:09 PM #635
July 1st, 2017 01:34 PM #636
Speedo? Normally cable lang yan...
Sent from Zenfone 3 on Tsikot mobile app
- Jun 2017
- 4
July 3rd, 2017 08:36 PM #637May recommended shop ba kayo para sa speedo? sabi kasi sa casa palitan yung instrument cluster pero di naman chineck yung cables kasi wala raw electrician nila. Ano pala recommended niyo na palit sa stereo kasi maluwag na connection nung face ng stereo. Thanks
- Jul 2017
- 1
July 5th, 2017 10:04 AM #638I know Crosswind (XUV) has an OBD2 'port'. It is located on the driver side near the door (under the dashboard). More like at the back of the 'fuse box' but have to access it underneath and not by the fuse box.
If you ask if it works, it is another question. But why have and OBD2 port if it doesn't work?
July 5th, 2017 10:14 AM #639
- Dec 2008
- 10
July 13th, 2017 04:05 AM #640
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
