Results 501 to 510 of 640
- Nov 2008
- 7
June 15th, 2010 11:23 PM #502
You're welcome.
I personally believe that there is nothing wrong with sedimentor indicator/sensor. There might be water in your fuel lines. (may have caused when you filled up fuel in a gas station where their diesel reservoir may have water or moisture) I suggest you bring down your fuel tank, have it drained and cleaned. taking the chance, clean up the fuel lines too.
- Jun 2010
- 2
June 16th, 2010 12:56 AM #503Hello! Meron kami Crosswind XUVi and I'm planning to use it to tow a trailer with race car on it. kaya ba handle ng crosswind yung towing duty?
June 18th, 2010 03:59 PM #505
- Jun 2010
- 11
June 21st, 2010 02:48 PM #506
June 21st, 2010 08:30 PM #507
Simple, go out of the vehicle. "ARM the vehicle. manually open the door using your vehicle keys. If the alarm goes off, it's likely a busted LED/faulty wiring supplying electricity to the LED. If the alarm does not go off, your alarm is likely at fault.
Eitherway, walang isang problemang di nagagawa. Bring the unit to a CASA and the supplier of the alarm would have technicians who can check your alarm. If no mods were done in connection to the alarm and the vehicle is still under warranty, you might even have the alarm replaced/fixed for free!
- Jun 2010
- 87
June 22nd, 2010 09:17 PM #508Good pm, have a plan to change my tires ( Goodyear Fortera ) to mechelin or maxxis, ask ko lang if pwede mag-add sa series...mine is 235/70R/15 then gusto ko ilagay ay 235/75R/15, is it possible...for my computation is mag-add ang tire diameter for almost an inch, so it means less speed...need advice po mga bro...thanks in advance
June 22nd, 2010 09:18 PM #509
Yep ok lang iyan.
So instead of 70% of 235 yung sidewall height, 75% na. 5% isnt' that much. Just a few mm.
Use an online tire calculator to help you
- Jun 2010
- 87
June 22nd, 2010 09:21 PM #510im almost using this xuv crosswind A/T for a month, 30000 km in odo, my question is the fuel consumption, i got only 7 to 8 km/liter, mix n po yon ang city driving and hatawan, im living in lipa city batangas...regular nman ang pms nito, any suggestion..
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
