Page 51 of 51 FirstFirst ... 414748495051
Results 1,001 to 1,020 of 3710
    Aug 2017
    Hmmm..may lakas paba ang hatak?nagbabawas ba ng langis?pag paakyat kaya naman ba?
    Sent from my CAM-L21 using Tsikot Forums mobile app
    Aug 2014
    Quote Originally Posted by Edric_24 View Post
    Pinak check ko sa Isuzu normal pa daw need lang i flush yung radiator. Dahil simula nung nilabas namin nung 2004 hindi pa Nagagalaw Pag pinalinis ko pure Coolant ang ilagay ko.
    Sent from my SM-G950U using Tapatalk
    Aug 2017
    Meron ba kayong PDF ng Sportivo 2012 Owner's manual?
    Quote Originally Posted by fsinagui View Post
    RHD
    https://www.chevrolet.co.in/content/...I-28287013.pdf
    May 2019
    Hindi naman po sportivo yan eh.. naghahanap din po ako owners manual po sportivo x.. hindi na po kasi alam san nalagay po yung sa amin..
    Aug 2017
    Quote Originally Posted by timming_gear View Post
    D ko sure kung maniwala ka..ung crosswind ko ay 349000+ na tinakbo,pero hindi na sya na overhaul sa engine..injection pump pa lang nabuksan sa kanya..may usok din sa dipstick pero normal lang nmn daw yun.kaya pa din akyatan,kulang lang talaga sa speed..gang 80 lang kc ayaw ko na tapakan pa dahil lalakas sa diesel..proper maintenance lang yan like regular change oil,fuel filter,air filter,oil filter
    Aug 2014
    Mas mataas mileage mo matibay talaga . Kame rin ok pa naman pero haggang 90kph na lang ang sagad Kaya rin siguro hindi bumibigay pa 1st owner kase kmi at nakabisado na. So far wala pa major rin nasisira.. Sa temp. Lang pina check ko s isuzu normal pa.naman daw. Pero ipapa Overhaul ko na yung radiator at mapalitan na ng coolant para walang kaba, simula nung inilabas nung 2004 hindi pa Nagagalaw [emoji846]
    Aug 2014
    Try mo remove fuse nung sa audio para mawala kuryente.. or disconnect battery.
    aio....
    Sent from my mobile phone using Tapatalk
    Apr 2008
    Ganda sana if they gave it more power while they were at it. But as it is I see droves of jeepney operators getting this. Probably the only old school diesel in the market rated Euro 4. Fuel consumption matching modern CRDis with old school diesel maintenance cost! May nanalo na!
    Sent from my SM-G965N using Tapatalk
    hello po. NagpaPMS ako ng Sportivo 2010 namin kanina (plus change oil and ATF dialysis). Per checking nila sa ilalim, ang daming need palitan 😭
    Center Post 3k
    Ball joints 5k
    tie rod 2k
    idler 3.5k
    Transmission Oil seal 4.5k
    wheel bearing 3k
    labor 3.5k
    Makatarungan po ba ang prices? Also, yung ball joints, idler arm, tie rods and center link were also replaced dec 2016. So normal lang po ba na for 3yrs, papalitan sila ulit (Im driving daily house to school ng mga kids po then mga once a yr na long drive, if this will help 😅).
    Also, do you regularly do ATF dialysis? Every when?
    Baka meron sa inyo need ng mirror ng side mirror ng xto pang left driver side s meron ako for FREE nakakalat lang kesa itapon mapakinabangan ng iba. img_20210412_180443.jpgimg_20210412_180453.jpgimg_20210412_180447.jpg
    Sent from my POCOPHONE F1 using Tsikot Forums mobile app
    Apr 2009
    Quote Originally Posted by x-wind View Post
    Sir I have a 2001 XTO . nasa inyo pa po ba side mirror? sira po power ng left side ko and yung spring sa loob na repair na dami na rin gasgas kaha. thank you po
    Apr 2009
    Now lang ako uli nakabalik sa tsikot, I miss this site. trying to log in but hindi ako makapasok maybe marami same as me.
    Anyway I still have my XTO , just have it calibrated nag iba takbo niya its a 360 turn for me. Before 3rd gear naka AC hirap na siya paakyat now kahit may kaunting bwelo hataw na siya. Naisip ko nga all those years maybe eversince i got my xto tiniis ko yun, i should have done it years back. now i enjoy my ride even more. It runs like new for me.
    before ko pina calibrate ang issue ko lang naman yung feeling ko bitin ang takbo pero even before hindi siya mausok , pass siya sa mga emission.
    Now ko lang din nalaman the smoke emission can be adjusted, nung after calibration I noticed the power and accelaratoin pero naging mausok. i asked the shop why and they just adjusted something ayun less usok, i think it will pass emission test.
    sorry for the long msg just miss this
    thank you
    Jan 2008
    meron fuel supply adjustment sa injection pump.. pwede mo palakasin or sakalin yan.. of course may kapalit yung lakas.. usok..
    kaya dapat tama lang sa adjustment..
    Apr 2009
    sa ngayon tama na sa gamit ko. satisfied with the power but just a little smoke .
    Thank you
Isuzu Crosswind Owners Thread [continued]
