Page 150 of 186 FirstFirst ... 50100140146147148149150151152153154160 ... LastLast
Results 2,981 to 3,000 of 3710
    Jun 2012
    #2981
    The reason is kay rapide mo dinala. Try mo sa iba
    Posted via Tsikot Mobile App
    May 2009
    #2982
    Quote Originally Posted by jayen View Post
    Crosswind XUVi A/T 2005 model. Nagpa overhaul and calibrate ako ng injection pump.
    CHECK TRANS tapos hindi na nagpapalit ng GEAR pag nag nakaDRIVE? Dinala ko sa Rapide, did engine scan pero hindi madetect kung bakit ganun. also changed ATF, ganun padin. any thoughts? thank you in advance.
    ang modelong iyan sa pagkakaalam ko e hydraulic shift via sa throttle valve cable (kickdown tawag ng iba). yang TV cable e kunektado sa injection pump. maaaring nawala sa dating settings yung tension (or some adjusting nut) nung tv cable. tignan mo muna. worst case scenario e naputol or nadislocate yung koneksyon sa loob ng valve body yung cable.
    next time wag ka sa rapide. rapide din masisira ang sasakyan mo nyan. hahahaha
    Feb 2015
    #2983
    hello po mga bossing...cno po may alm within qc n mgling sa turbo ng crosswind?feeling q kc cra turbo ng gamit q n xt e....salamat po..
    Feb 2015
    #2984
    MGA SIR ! ANO PO BA MAS MAGANDANG CROSSWIND 2003 XUV o XUVi o XTO, matic lahat. Ano po ba difference at alin mas tipid pang negosyo
    Jan 2014
    #2985
    XTO mas lighter siya means better acceleration and lower center of gravity
    XUV Macho looks with all the amenties and leather goodies
    XUVI has everything including first mounted 5.6" lcd monitor on auvs plus karaoke mike and remote
    more cupholder
    more cupholder
    #2986
    kailangan po ba mg turbo timer ang XT variant?
    Mas ok po ba ang aircon ng crosswind (after years of usage) compare sa adventure?
    Mar 2015
    #2987
    Quote Originally Posted by Dudee View Post
    We have a 2006 XL na crosswind. and yung evaporator palang sa likod ang napapalitan namin. So for wala nang ibang issue and mas malamig ang aircon compared sa revo ng inlaws ko. sadly wala pa turbo to kaya ang kupad.. hehe
    #2988
    are there available cup holders na pwede ikabit sa XTRM?
    #2989
    Just follow the PMS schedule for aircon la sya problem sa akin 2001 model until now malamig palang once palang nagpalit ng dryer.
    #2990
    may hatak na ba ngayun yun latest model ng mga automatic na naka turbo before kasi super kupad nya lalo na sa akyatan. thanks
    #2991
    May hatak na ba ngayun yun mga bago Automatic na naka turbo before kc super bagal lalo na sa akyatan yun mga A/T with turbo.
    Jan 2014
    #2992
    Quote Originally Posted by x-wind View Post
    ^ May hatak naman ung 03 xuv a/t ko ah,
    di nga makasunod ung adventure na manual sa likod ko heheh
    at nakakaovertake ako ng mga 18 wheeler sa dalton pass
    Jan 2011
    #2993
    may hatak naman talaga ang crosswind a/t. kung gusto mong bumilis pa, adjust your injection pump. increase fuel feed, change setting on your fuel enhancement screw, try a half turn, clockwise. kaso, medyo lalakas kunti kunsumo sa krudo.
    Apr 2015
    #2994
    may lcd monitors ba sa second row ng 2015 sportivo x?if wala papano mag avail?may nakita po kasi ako na meron but sa mga pictures sa net e wala..thank you
    Jan 2014
    #2995
    alam ko may sportivo x na w/o lcd at meron namang w/ lcd syempre mas mahal ung may lcd pero di ko alam ngayong 2015 di pa ako nakakapunta sa casa
    Dec 2008
    #2996
    Tanong lang tungkol sa 2001 xto Instrument gauge. Gumagana ung fuel, temp at odometer pero hindi gumagana ang tach at speedometer. gauge na kaya mismo ang may problema?
    Oct 2013
    #2997
    Check your sending cable.
    Apr 2015
    #2998
    Meron po kaming nabili na 2007 Sportivo AT with Turbo. ang problem ko is mahina po syang humatak pagpaakyat lalo na pag puno. Tapos after ko i-release yung accelerator namamatayan ako ng makina. Tapos may leak po yung transmission nya(scheduled to be fixed pa po). Could that be the reason kung bakit ako namamatayan? and if ever po ba na magawa un lalakas po kay sya humatak pagpaakyat?
    Thanks!
    #2999
    Quote Originally Posted by NagaRaia View Post
    Thanks!
    Mabagal naman talaga ang AT pero hind katulad ng sinasabi mo mahina na siya humatak pag puno at na mamatayan. Change ka muna ng air filter (OEM) at yung fuel filter and see kung merong pag babago. If none pa check mo yung injection pump mo baka kinalikot ng dating nay ari at di na naibalik sa orig spec.
    Thanks!
    Mabagal naman talaga at AT pero hind katulad ng sinasabi mo mahina na siya humatak pag puno at na mamatayan. Change ka muna ng air filter (OEM) at yung fuel filter and see kung merong pag babago. If none pa check mo yung injection pump mo baka kinalikot ng dating nay ari at di na naibalik sa orig spec.
    #3000
    Recent namin panik sa Baguio nung Feb, yung XTO ko na minamaneho ng pinsan ko ay nakaka sabay sa Pajero ko at 140 kph sa SCTEX at TPLEX. More than that speed hindi na kaya. Yung sa Kennon road papanik naka buntot lang siya, late evening yung biyahe kaya maluwag. Apat ang sakay ng XTO at lahat ng bagahe ng dalawang sasakyan ang nasa likod niya.
Isuzu Crosswind Owners Thread [continued]
