Results 3,441 to 3,450 of 3710
August 19th, 2016 12:11 PM #3441
- Jun 2016
- 1
August 24th, 2016 07:36 PM #3442Good day! newbie here..does an Isuzu NKR fuel pump assembly have a built in fuel filter? Should I install a water separator apart from the pump assembly? The assembly is fitted in my XUV2003..tia
This is the model
Circuit No. CFP- 1IS
OEM No. 8-94154-754-5
Model ISUZU NKR(8mmpipe)
Brand: Circuit
- Apr 2009
- 551
September 2nd, 2016 06:10 PM #3443Quote Originally Posted by andongskee View Post
Good afternoon po! May alam po ba kayo na magaling na mag-aayos ng Manual transmission ng Crosswind(04XTRM)? Eto na nga po yung pinangangambahan ko...biglang may umingay...parang grinding high pitch sound sya especially kapag bibitawan mo ang accelarator kung naka third - fourth gear ka!!! Wala pong problema sa pagkambyo, pumapasok naman po with ease....its just that parang may mrt sa ilalim ng sasakyan ko pag release ng accelerator. Pag nerelease naman po sa kambyo mawawala ang tunog kahit tumatakbo ka pa ng 80 kph!
Kala ko po nung una eh Axle bearings, so I had both replaced. Di pa rin po nawala. So I checked the Universal joints...same...di pa rin po nawala.
Mga sir, baka po may alam kayong transmission specialist na may readily availbale na surplus parts? Checked brand new and its 38k kay jason. Surplus is 22k sa blumentritt!!! Tight po budget so kung ano lang po sira, yun lang po balak ko palitan!!! Ang sabi po sa akin nung pinasakay ko para maconfirm talaga na may naririg, ang sabi nya po eh baka main drive bearing ng transmission!
Salamat po!
QUOTE=einreb07;2747857]Boss tinignan nyo na po ba ung disk brake sa harap maigi, silipin nyo po baka napasakan ng maliit na bato.[/QUOTE]
Andongskee baka makatulong share ko sayo. sorry now ko lang nabasa.
possible kailangan mo ng palitan Clutch disk, pressure plate, release bearing and pilot bearing. gastos mo kasama labor around 6500. Napalitan na ba itong mga parts na ito sa sasakyan mo? nangyari kasi sa one of our delivery vans tumutunog pag change gears or pa tumatakbo, pinabayaan lang ng driver kasi nakaka change naman daw ng gears ang nangyari tumirik yung sasakyan nag lock na yung
pressure plate sa disc. ayaw ng gumalaw ang kambyo. or kulang lang gear oil sa differential kaya may ingay and check also transmission oil. sa gas station lang palagyan mo mura lang.
- Aug 2014
- 73
September 2nd, 2016 10:46 PM #3444help umiilaw yung oil sending unit ko pag naka drive yung kambyo ko pag naka neutral oark or iaabante ko nawawala naman. yung ilaw nya kurap kurap minsan steady ok ang level ng oil ko. ayokong isipin na may prob na ang oil pump ko
September 5th, 2016 03:33 PM #3445
kahit mainit o malamig ang makina at naka idle lang kamo umiilaw ang oil pressure warning light?
pero kapag aabante ka na or aatras nawawala naman?
nangyari na sa akin yung ganyan although ibang brand ng sasakyan. turned out na yung oil pressure switch ang salarin....subukan mo palitan tutal mura lang naman. less than P200 lang naman yung replacement brands.
mas maigi pakonektahan mo muna ng mechanical oil pressure gage para makita ang hot idle oil pressure at maximum oil [presure. kung within normal range e walang problema. yari na kung mababa pa rin oil pressure kahit irev mo engine.
September 5th, 2016 03:37 PM #3446
pressure plate sa disc. ayaw ng gumalaw ang kambyo. or kulang lang gear oil sa differential kaya may ingay and check also transmission oil. sa gas station lang palagyan mo mura lang.[/QUOTE]
kung pilot bearing kasi, maingay kahit nakaneutral or sa kahit anong vehicle speed...
kung release bearing naman, everytime na apakan mo ang clutch ang tumitindi ang ingay nito..
kaso 3rd-4th gear lang daw nangyayari, kaya i assume na nasa synchronizer, hub o mismong gears ng 3rd o 4th.
pinakamaigi pa rin na diagnosis e ibaba ang transmission at idisassemble ang laman loob nito.
September 19th, 2016 11:45 PM #3447
good pm, may nakapag palit na ba sa inyo ng sun visor? nabali kasi yung amin... bukod sa casa san po ba nakakabili? salamat!
Sent from my H940 using Tapatalk
September 22nd, 2016 12:20 PM #3448
recently acquired xuvi turbo a/t. while driving it along commonwealth, it doesn't or having a hard time go beyond 40kph.
parang mamatay. at one time. kahit anung apak ko sa gas wala nangyayari kahit baon na. i switched it off then restart nag ok pero ayun super bagal. kung baga parang naka 1st, 2nd gear lang. RPM seems can't go pass 2k.
baka may ma recommend kayo shop in qc/commonwealth area. thanks.
September 22nd, 2016 06:57 PM #3449
September 23rd, 2016 05:28 PM #3450
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
