Results 2,061 to 2,070 of 3710
- Jul 2007
- 4
June 28th, 2012 01:56 AM #2061Sirs, question lang po sa alignment. I have a 2005 XT. Possible bang magkaron ng mis-alignment sa rear wheel or lagi lang talagang sa front?
Napansin ko kasi na yung outside wall nung rear wheel ko eh mas lamang ang pudpod so I had it checked sa service center. Possible daw na nung nasa front pa yung gulong nangyari yun ( I had my wheels rotated 3 weeks ago) and ngayon ko lang napansin.
Sabi nila wala daw alignment yung rear ng crosswinds natin and front lang ang meron. May problema yung camber alignment so pinaayos ko na agad. Sabi nila hahabol din ang kain nung rear wheel so no need to worry.
July 2nd, 2012 05:21 PM #2062
Sirs question po.normal po bang hirap umabot ng 100-120kph ang crosswind xuv a/t?tia
- Nov 2011
- 4
July 2nd, 2012 06:12 PM #2063newbie question lang sir. got a 2011 xuv last nov. since then dikopa binuksan yung radiator cap. how to maintain the temperature, like tuwing kelan dapat icheck yung radiator tank. o kahit sa reservoir lang muna ang concern ko? and suggest narin po kayo ng coolant na maganda. tnx!
BANNED BANNED BANNED
- Jul 2008
- 99
July 4th, 2012 03:25 PM #2064Ray_An,
twice na ata akong naka-experience ng ganyan, and on those occasions the culprit was always the WATER SEPARATOR and the FUEL FILTER...
Here's a view of water separator:
http://t3.gstatic.com/images?q=tbn:A...fmKq0INLMyKpBw
- Jul 2008
- 99
July 4th, 2012 06:32 PM #2065Here's whats blocking my fuel system... mga mala buhangin na dumi... same residue could be seen inside my fuel filter when it was removed... kaya pinalinis ko na lang itong water separator and then replaced the fuel filter mahirap ng tumuloy tuloy pa papuntang makina. After that wala na yung parang sakal na acceleration o yung pupugak pugak pagkaapak ng full speeeeeeedddd..hehe
July 5th, 2012 03:41 AM #2066
planning on getting crosswind maybe next year.. tanong lang, ilang RPM ba normally ang baseline when your cruising speed is 100kph?
(per experience w/ petrol engines 1.6L - 2.0L 5 speed manual, its within 2.8k~3k RPM)Last edited by ash0279; July 5th, 2012 at 03:41 AM. Reason: typo
- Sep 2008
- 295
- May 2012
- 85
July 5th, 2012 02:48 PM #2068Was able to get a Baldwin B109 for Isuzu Crosswind. Word of caution: It only fits the turbocharged engine. For the NA 4JA1, use the B1446 to be sure. Top mounted kasi yung filter nang NA engine, kaya kailangan mas maliit. Di na kinabit kasi sumasabit. Yung sa turbo kasi sa baba kinakabit, kaya may clearance for the filter diameter
But i was able to use the Baldwin BF954 fuel filter without any problem
Im selling the oil filter (wala na pong plastic dahil nga tinry ikabit). Las Pinas/Makati Area po
Salamat!
- Jul 2012
- 1
July 5th, 2012 08:54 PM #2069Tsikoters, tanong lang po, Mine is a 2011 Crosswind..i lost the key for the spare tire..san po ba pwd makakuha ng spare key?
July 6th, 2012 12:06 AM #2070
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
