Results 611 to 620 of 3710
- Nov 2007
- 412
December 31st, 2010 08:37 PM #611
- Aug 2009
- 349
December 31st, 2010 11:07 PM #612HAPPY NEW YEAR!!! :party: mga fellow tsikoters....
Nakaka excite at interesting nman po yung mga e-momodified nyo this coming 2011... Samaaa po ako dyan! hehehe....Make our beloved isuzu xwind more powerful & fast..... Thanks! sa mga pix & infos mga sir's....
January 1st, 2011 02:12 AM #613
[SIZE="5"]OT Muna:[/SIZE]
[SIZE="7"]HAPPY NEW YEAR Tsikoteers!!![/SIZE]Last edited by Benzmizer; January 1st, 2011 at 02:19 AM.
- Nov 2006
- 41
January 2nd, 2011 01:49 PM #615mga sirs ilan ba engine support ng crosswind and where it is located?transmission support meron din po ba?panu po malalaman na sira na medyo malakas kasi vibration kapag 750 lang rpm ko e?TIA
January 4th, 2011 02:56 AM #616
ask ko lang po sana regarding backup sensor if normal ba to hear an initial long beep when you shift to reverse? I was expecting kase to just hear a short beep telling you that backup sensor has been activated. It's been like this since I acquired the vehicle, kahit walang obstruction, nakakahiya sa mga passengers ko coz talagang masakit sa tenga. the rest of the beeps naman works normally when detecting obstructions.
- May 2009
- 119
January 4th, 2011 01:35 PM #618hello to all tsikoteers!!Happy new year to all!!
Sir Benz and All Gurus...
tanong lang kung ano ang maximum diameter ng brake drum ng crosswind (rear)?ano po kaya ang max diameter nito due for replacement?saka nagsqueak na ang brake lining ko sa likod eh eventhough not using the brakes..indicating na manipis na lining..mga ilang months pa kaya pwede itagal nun? and lastly magkano po kaya set nun including the drum sa Jaysons or sa Casa?thanks po...
- May 2009
- 119
January 4th, 2011 01:39 PM #619hello po ulit..
hello sir Benz..
I hope you could address my problem to your Isuzu friends and contacts...bale yung bench type po kasi na upuan sa front ng crosswind ko (XT 05) ay napunit yung leather niya sa back then upon checking may flat bar that serve as back support na napakatalim or talas ng edges niya kaya napunit yung leather niya (around 24 inches). Bale nakatapat po ito sa tuhod (knee) ng nakaupo sa 2nd row and ang worry ko makahiwa ito sa nakaupo sa 2nd row kasi sobrang talim talaga niya..will post picture po soon...kasi safety related din po ito..
- Dec 2010
- 46
January 4th, 2011 02:03 PM #620mga master/s questions lang po.last time may leak po kasi yung power steering.per checking yung power steering hose ang may prob.
so ni replaced po nila yung hose.ngayon po parang may naririnig akong parang may contact ng metal to metal pag naka center
position yung manibela, pero dati wala po sya ng may leak pa.
heto po yung tanong:
may effect po ba pag ibang ATF ang nalagay/naidagdag, let's say hindi sya DEXRON compliant?
ok lang po ba i drain yung ATF na ipahigop or mas ok na magdisconnect ng hose?
ano po ba ang best practice sa power steering, ATF or yung talagang power steering fluid po?(pros and cons)
ano pa po kaya ang possible remedy?
Firefox browser - :wonder: may error kapag mag attached ako ng piktyur sa computer ko insert image...
Problems with viewing Tsikot on non-Chromium...
