Results 1 to 10 of 1770
    Aug 2004
    A manual Sportivo should be able to hit 140 km/h on the NLEX or Skyway. But you should be careful, as there isn't enough suspension control to to keep you planted if you hit a big one at those speeds. And without ABS, you're in danger of locking the brakes in an emergency.
    A Crosswind is most comfortable at 80 km/h on most roads. That's the best speed to attain 14-16 km/l on the highway, too.
    Jun 2007
    thank you for the reply sir niky , i really apreaciate it. sir like sa adventure or auv na rim14 as compared to rim15, with regards to the speedometer, if iyung auv na rim15 is running at 120kph, would it be around 130kph kapag rim14 ang nakakabit? wala pa lang kasing budget but i really would like to change the tires to bigger size like 245/75r15 para mas medyo stable sa road but would it mean that the speed again would have a change? thank you sirs
    Aug 2004
    Use this: http://miata.net/garage/tirecalc.html to see the difference.
    Stability on the road is dependent on both the width: "245" and the height/profile: "75". Generally, wider tires are more stable, but are more susceptible to hydroplaning (nadudulas pag dumaan sa puddles) and tramilining (makulit pag maalog yung kalye). Tires with lower profile are generally more stable, but more susceptible to damage from potholes.
    Jun 2007
    thank you again sir, you've help a lot regading my inquiries, pudpurin ko na lang muna gulong ko, sayang rin
    and have just read , happy birthday sir
Isuzu Crosswind Owners Thread [ARCHIVED]
