Results 181 to 190 of 1770
April 4th, 2007 06:25 PM #181
Driver/PasaHERO
- 1,310
April 5th, 2007 06:55 PM #182ann32, if you plan to get a crosswind, get an XUV, puro amenities lang nman ang difference. Kaya lang kumuha family ko ng sportivo, kse un gusto ni erpats, ang tigas ng ulo d ko masabihan kse majority ng gastos sa kanya hehe
BANNED BANNED BANNED
- 3,790
April 6th, 2007 09:01 AM #183una ay mapapaso ang waranty mo...any problem na redeemable as factory defect and therefore covered ng waranty can not be claimed anymore.
long term, mas malaki ang chance that the engine will wearout faster...you are using oil in the engine. and heat and oxygen will tend to degrade the oil so kung hindi ito napapalitan regularly, it can pose some problem in lubrication. low lubrication leads to friction and increased in friction on metal parts will cause it wearout faster.
Ideally change oil and filter every 3months or 5,000km (whichever comes first)if you are using regular oil. Synthetic oils can go as high as 6months or 10,000km.
Other parts like belts and air filter can easily be adjusted or replaced anyway. brake pads if not nabantayan ng tama can lead to poor wear or even poor braking (delikado sa inyo).
You have been using it for 17 months and 10,000km without maintenance! wow....that is an abuse of the vehicle. I hope napapaengine cleaning mo man lang sana ito?!?
Another possible that should be near wearing out is your batteries....they usually die at around 24 months (without neglect) and yours seems to be neglected for 17 months na....so hindi ako magtataka if it suddenly dies on you.
HTH
- Apr 2007
- 2
April 10th, 2007 01:50 PM #184*wildthing
maraming salamat sa advice mo. from now on ill make sure to change oil/filters every 5km.
yesterday nagpunta ako autoshop for change oil and tune up pati breaks pinacheck ko na din at pinarotate ko na din yung gulong. so pinalitan air filter at oil filter at nilinis air cleaner. yung transimission oil at gear oil daw pinapalitan lang pag nagka-leak sabi ng makaniko. tama po ba na hindi kailangan palitan ang gear at transmission oil unless may leaks? if not, tuwing kelan po ba dapat magpalit ng gear at transmission oil? also yung power steering fluid at break fluid dapat din bang palitan o kailangan lang palaging tama ang laman sa oil reservoir? please advice me po and sensya na kayo for being noob hehe thanks!!
April 11th, 2007 01:45 AM #185
May bumibili pa rin ba ng Crosswind?
We had 1 before..
Sound like an Isuzu ELF... Drive like a Truck....
Built the way SARAO is built....(joke) Look kayo sa thread ng HYUDAI STA FE...
Sasakit Ulo ninyo dito..
Leaking Oil
Mis-align chassis
Napuputol na tambutso......
Pero kung antukin ka e ito ang para sa iyo... Sa sobrang ingay nyan e siguradong hindi ka aantukin..
- Dec 2006
- 64
April 15th, 2007 12:26 AM #186
Driver/PasaHERO
- 1,310
April 17th, 2007 03:13 PM #187kaka 10K kms lang nung sportivo namin, kung sa iba namin pa maintain ung sasakyan sa 10K kms nya, nde ba mavo void warranty nun?
April 17th, 2007 05:56 PM #188
Dapat hindi, but the casa will take any excuse they can get... In the US, casas cannot void warranty if you go to an accredited 3rd party service center. Here in the Philippines, they'll void it anyway.
- Apr 2007
- 4
April 18th, 2007 03:01 PM #189pati ba warranty ng ibang parts like power window mavoid din warranty pag sa iba nagpa-pms?
April 18th, 2007 03:22 PM #190
Void lang ang warranty ng engine. Pero depende na lang yun sa kausap mo.
high idle RPM at engine start
