Results 991 to 1,000 of 1770
October 24th, 2009 01:20 PM #991
mga sirs/madams.,
ask ko lang kung ano difference in terms ng liwanag, between projector type head lamps at ung ordinary halogen headlamps? alin ang mas maliwanag sa gabi?can anybody differentiate the two?
thanks and more power sa mga xwind owners out there.....
October 26th, 2009 09:50 AM #992
From what I know, projector headlamps provide "farther" light range but with narrower (width) range. This is also the reason why there are non-existing projector headlamps that is with low/high bulb combo. There is a separate HI BEAM.... where H4 (smoked or crystal) is the opposite. It provides wider light range.
But in terms of "brightness", it should be the comparable.
October 29th, 2009 09:15 PM #993
I see, so di naman pala significant in terms of brightness, just the reach. Anyway I was planning sana to upgrade to projector lamps pero medyo may issue sa pricing so postpone nalang muna until next year or until kaya na ung pricing, medyo mahal din kasi ung projector headlights.
October 30th, 2009 11:26 AM #994
October 31st, 2009 01:45 AM #995
November 3rd, 2009 12:32 PM #997
Why not? Basta when you request for a quote sa CASA, get the quote for a 2010 headlamp assy para when claim is granted, pasok sa budget nung 2010 headlamp assy.
Bad I know but I did this with my 1997 Cefiro before. Did the "hammertime" job on the rear garnish/tailamps to upgrade to a 1998-99 look.
November 4th, 2009 12:45 AM #998
November 4th, 2009 11:00 AM #999
sir benz, question lang. i bought a bike rack installed at the spare tire and i used to load my bike in there. my question is...indi kaya masira yung bisagra nung pinto nya sa likod, since nadagdagan sya ng weight? matibay din kaya tong bracket ng spare tire natin? btw, my ride is 08 xuv. tnx
November 4th, 2009 05:12 PM #1000
No worries. Your back door hinges would hold up.
I have no photo but I have seen the "reinforcement" used on sporty models' backdoor. Matibay talaga and I'd say it may have been "overdone". It is even more likely that the sparetire carrier at the back may give in but surely not the reinforcement where it is attached.
high idle RPM at engine start
