Results 731 to 740 of 1770
August 8th, 2009 01:15 AM #731
Wow! Triple post!!! Sorry, website timeout!
August 8th, 2009 01:25 AM #732
Anyway, before you worry of what tires or rims to put on your "soon-to-be" Crosswind, just make sure first that you get a good unit. Remember, XL variants of the Crosswind are "normally" fleet units or used for commercial use. Expect that medyo gamit yung unit na titignan mo.
Check the Maintenance Booklet for PMS performed on the vehicle.Last edited by Benzmizer; August 8th, 2009 at 01:32 AM.
- Jan 2008
- 38
August 8th, 2009 01:50 AM #733
- Jan 2008
- 38
August 8th, 2009 01:59 AM #735
Happy to be of help.
I and the rest of the guys here are more than willing to extend to newbies like you what we know.... and in some case, we learn from others like you too!
As for the XTi rims, they are 6x15 in size. I'll PM you for other details. Now since these are 15s, you would need to replace your current tires too. Correct tire size on a 6x15 rims are 205/65R15. The stock tires used by XTi units are Yokohama.
You got PM!
- Sep 2007
- 174
August 8th, 2009 06:35 AM #736Direstso na kay Benzmizer..onboard guru...
When I pressed the brake pedal of my xto at lets say...80 kph...nagvivibrate and brake pedal. Is this normal?
My City and L200 don't have vibration in the brake pedal even at higher speeds.
My brother who owned the xto mentioned he had the brakes repaired or had some maintenance done.
August 8th, 2009 08:50 AM #737
First, I really appreciate the fact if I seemed to project that I'm a know-it-all guy --- THANKS!--- but I'm not. These are just based on information/experience I have had that I would like to share to others. That is where self fulfillment comes in.
As to your concern, have your rotor discs and brake pads checked. These are signs of either uneven pads wear or a thin pads resulting to rotor disc touching. This is a safety item of any vehicle. Please have it checked ASAP and prioritize its repair.
August 8th, 2009 11:13 AM #738
HI Benz,
Our mechanic told me to replace the ff. parts since i'm already experiencing sliding clutch.
- Pressure Plate
- Clutch Disc
- Release Bearing
Would you happen to know where I could get original isuzu parts? I already inquired at Jayson's Auto Supply He told me the following prices, are these prices okay I mean for an original isuzu?
- Pressure Plate - Php2400 Orig (Jayson's) Php3000 Orig (Our Mechanic)
- Clutch Disc - Php2400 Orig- (Jayson's) Php1800 -Replacement Part (Our Mechanic)
- Release Bearing - Php1100 Orig (Jayson's) Php550 -Replacement(Our Mechanic)
August 8th, 2009 11:20 AM #739
I also inquired at Walco's, here are the prices.
- Pressure Plate - Php2800
- Clutch Disc - Php2700
- Rotor Disc - Php1200 japan replacement - Php7000 -Orig Isuzu
August 8th, 2009 11:13 PM #740
Partner, according to my "bubuwits", Jayson's parts are Genuine ISUZU parts. Talagang matindi lang syang magbagsak ng presyo kaya sapol mga CASA. Not sure also if he extends parts guarantees. Alam ko mga CASA meron.... unless you buy it from them and have someone else install them. If damaged yung piyesa, subject for evaluation pa yun if part defect or if caused by improper installation by your outside mechanic.
I have heard that there are a good number of ISUZU users buying from Jayson's and they are satisfied with the quality of his parts. His price seemed competitive too.
Teka, bakit may rotor disc quote ka dun sa isa? Palitin na din ba? Malalim ba sugat? Di kaya reface?
I just imagine it's a manual especially at low speeds or while maneuvering on inclines. Nature of...
(2023) Ford Territory
