Results 21 to 28 of 28
February 10th, 2011 05:36 PM #21
- Mar 2011
- 2
October 25th, 2011 09:41 AM #22Mga Sirs, ask ko lang po kung may naka experience na sa inyo ng pulsating tightness when turning the steering wheel either way? Na check ko na po kasi yung pump, ball joints, tie rod ends, suspension bushings and ok naman po sila but the problem is still there even when the engine is off or the front is jacked up. my suspect is the gearbox, ano po kaya ang cause nito? Napalitan ko na rin po ng fluid. TIA!
June 9th, 2014 07:05 PM #23
Steering pump pulley ng XTO ko biglang nabunot sabay tagas ng PS fluid. Pati mechanic kong kakilala nagulat dahil nabunot. Naubos daw ang bearing
June 9th, 2014 09:52 PM #24
^hindi nag squeak yung belt before masira bearing?
Posted via Tsikot Mobile App
June 10th, 2014 08:55 AM #25
Parang sipol na paos, akala ko nga baka maluwag ang nuts ng gulong, tapos sinubukan kong i-0ff ang a/c at nawala.... then yun na nalaglag na, akala ko oil filter etc. Mabuti na lang at salamat ilang metro na lang sa bahay kaya naipasok ko pa ng paatras kahit tigas na ipihit. Nare-repair ba yun? Sabi kasi ng mech tingnan daw niya kung ma-repair o hanap ng surplus......Well, ganun talaga mag 13 years na rin si XTO ko pero wala pa 60K kms ah!
June 22nd, 2014 12:03 PM #26
- Dec 2015
- 32
February 5th, 2016 04:28 PM #27sir fabilioh, any updates po sa prob niyo? pump po o gearbox kinauwian? same po kasi tayo ng situation, sa una magaan pa, pag mainit na makina at medyo matagal na ginagamit bumibigat lalo na pag mainit na makina tapos running at bigla ka huminto, bigat ikut ng manubela.. plano ko narin bilhan bagong pump kasi pinaoverhaul ko pump walang pagbabago tapos humanap ako ng iba mekaniko at inadjust ung spring ng pump, may improveness ng konti pero hindi parin ako satisfied, gusto ko rin kasi maging sure kung palit pump na talaga un nalang din kasi iniisip ko.. gearbox ko kasi tuyo din sya..
July 17th, 2016 11:49 PM #28
It happen also sa 2001 xto (245k kms) ko last friday. nabunot din kaso nawala yun akin pulley and shaft kit gastos umabot ng 7450 DIY pa ang pullout and install.
Kaya sa nga naka crosswind na di pa nag papalit ng bearing stering pump bili na kayo ng kit 1250 lng yun kay jason included all oring and bearing.
Sent from my SM-J700H using Tsikot Forums mobile appLast edited by x-wind; July 17th, 2016 at 11:56 PM.
Xiaomi E-Car
