Results 11 to 20 of 26
- Jan 2010
- 5
January 15th, 2010 12:57 PM #11alam ko to adjust sensitivity... press and hold (sabay) yung lock and unlock button for 5 secs then may chirp na tutunog.. then press yung panic button accordingly level 1- 1 chirp, level 2- 2 chirps and so on.. pinakasensitive yung level 1.. less sensitive yung level 7
January 15th, 2010 09:52 PM #12
- Nov 2010
- 35
November 27th, 2010 09:54 AM #13gurus,
totoo po ba na may motion sensor at sound sensor(mic) ang mga alarm like IATS.
mukhang may problem kasi yung alarm ko na try ko na adjust sensitivity from 1-7. pag 4 (factory setting) panay ang alarm sa ingay sa kalye pero kahit sipain ang gulong at alogin ko na nakatapak sa running board buksan ang knob ng pinto ayaw naman mag alarm.
sa setting 1 or 2 yun pagsinipa gulong(front wheel lang rear wheel no response) nag alarm na pero kahit buksan yung door knob ayaw pa rin. pero very sensitive sa ingay or kahit walang ingay panay ang alarm.
please help...thanks
November 27th, 2010 12:06 PM #14
From my knowledge, di motion sensor meron ang Crosswind. Shock sensor lang and intrusion. I cannot explain why sa "sound" sensitive yung alarm while sa "galaw/yanig" ayaw. Just the same, I would suggest that you set the alarm 2nd to the least sensitive setting since what is most important lang naman is kapag may forced entry, tutunog yung alarm, not kapag nagalaw. (thou this would increase the chances of exterior items [i.e. sideview mirror, centercaps, etc] being stolen without the alarm going up)
November 28th, 2010 02:19 AM #15
- Nov 2010
- 35
November 28th, 2010 02:56 AM #16thanks sir benz
i see, kala ko may problema IATS wala kasi nabangit sa manual even yung reset button, para saan po ba yun?. it means na level 6 lang dapat kasi yung least ay level 7 at pinaka sensitive ay 1.
sir kahit kaya reserbang gulong pagdahan dahang tinanggal di rin ramdam?
November 28th, 2010 10:33 AM #17
Hmmm, not sure but from my knowledge, 2005 (start of Sportivo) nagkaroon ng IATS. Models (2001-04) prior to Sportivo just had keyless entry... ergo, no alarm.
Alam ko yung reset button is to revert setting to default (factory settings). No worries about your sparetire being stolen, there should be a lock for both the tirecover and sparetire before they're removed.
- Nov 2010
- 35
November 28th, 2010 10:46 AM #18Alam ko yung reset button is to revert setting to default (factory settings). No worries about your sparetire being stolen, there should be a lock for both the tirecover and sparetire before they're removed.[/QUOTE]
sir benz
factory setting it means na level 4 (grabe pa rin sensitive) sa ingay kaya minsan akala ko may problema alarm, ill take your advice na second to the least ang set ng sensitivity. saan po ba makikita noise sensor nito at yung iba pa ang nakita ko lang kasi yung sa hood?
meron po ba tayong mabibiling additional sensor for motion but still yung IATS pa rin ang main brain?
November 28th, 2010 03:08 PM #19
I am unsure of that since from my understanding, the module is the one that provides all the features of an alarm system, IATS or aftermarket. I doubt if the IATS has this feature (since if it had that, it would have been part of its standard features).
Short of saying, you may likely have to replace the current IATS of a reputable aftermarket alarm system that has this feature programmed in its module.
- Nov 2010
- 2
November 30th, 2010 01:31 PM #20Sir my nabibili bang IATS sa casa and kung meron mga magkano kaya ito. Nawala po kasi yung isang remote ng crosswind namin balak ko sanang papalitan nalang yung alarm since wala namang nabibiling spare remote.
Same design language across the range is fine Porsche, Audi, VW, Lexus and Mazda are all like...
China cars
