Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Mga Tsikot peeps,
    Hingi lang ako ng suggestions on how to improve the ride of an Isuzu Highlander XTRM at the back (2nd row and third row) to give more comfort to the passengers. Me nabasa akong thread before about inverting a leaf or two, but didn't understand this clearly. Me mga thread din before about changing shocks but nothing was mentioned about Highlander.
    Please suggest ways to improve riding comfort.
    Thanks in advance.
  2. FrankDrebin Guest
    nakikipost lang po....pang family ride ko kasi yun eh.
    medyo matagtag nga po siya lalo na kapag solo ka lang sa loob.
    Quote Originally Posted by stroker_200
    You could buy some leathrette seatcovers with added foams in it. Para mas malambo upuan and sandalan. Modifying your suspension settings would be helpful, but are you willing to compensate the cargo capacity it can carry? Taking a leaf spring out or inverting it will definitely improve ride comfort but cargo-wise will be limited to half of it.
    Opting for a more street friendly tire with softer sidewalls can be helpful. But this will cost you more.
    One more note in hand, never ever match gas filled shock absorbers with leaf springs. This will tend to have a harsher ride.
  4. FrankDrebin Guest
    Ungas,
    merong model ng XTRM na full grain leather seats na.
    ang alam ko double action yung front shock niya.
    BTW , your right about the tires kasi Michelin LTX/AT ang standard dun, matigas ba yun?
    Another one, kapag Leaf Spring ang suspension EXPECT THE HARSH RIDE, am I right Diesel Peeps?
    if you dont want to lessen your cargo carrying capacity but still want to improve the ride i suggest that you put a metal spaces between the shortest leaf spring and the one before it, about 5-8 mm thick so it will not function when there is no load, it will only function if the springs are compressed due to the load. it is the oveload spring that makes it ride harsh. and you can add a boomerang shackle.
    metal spacers :?: could you explain it further, what is it, where to buy and how to install
    what is a boomerang shackle
    any ballpark figure on the cost of these
    THANK YOU
    the spacer you can make one by looking for an old leaf spring that is the same width as your orig ones and have it cut put a hole in the middle for the center bolt. the boomerang shackles are like your ordinary shackle but its shape when mounted is like an inverted L, the theory behind it is that the shackle position is laid backwards and it should move easily than straight ones, physics i guess.
    cost would be about 2.5k all in all. the spacer job is a DIY.
    Quote Originally Posted by FrankDrebin
    Ungas,
    I was referring to stroker_200 added pads for 2nd and 3rd row seats, if the XTRM models do come out with leather seats then re-upholstering them with more paddings underneath it is the only solution.
    Michelin LTX/AT are all terrain tires with tougher sidewalls than the ordinary street ones. Matigas po ito and a much stiffer with hard compounds.
    Not necessarily harsh but stiffer than coils. Magaan kasi ang body ng AUVs kaya medyo matalbog sa likod. Not like US large sedans which some old models had leaf springs but mounted on a heavy body kaya hindi ito matalbog.
    When modifying shackles or adding lift blocks, please do also check the shock absorber extension and compression movements. They might bottom out on your ride.
    thanks sa mga nag-reply.
    Question lang po ke Ungas. About inverting leaf springs, me masa-suggest ka bang talyer na gumagawa nito. Gusto kong pasyalan sana para maintindihan ang gagawin, at matanong na rin kung gaanong load na lang ang puwedeng ikarga, at iba pang side effects.
    Question for ARB. Me alam ka bang talyer na puwedeng gumawa maglagay nung spacers. Pa recommend na lang.
    Dec 2002
    how does double action shock absorber works?
    iba ba ito sa regular shock?
    stroker_200::: I don't have an idea where they invert the leaf springs. Better PM wildthing sya yung nagpost nito on some previous threads. Nabasa ko lang that it will reduce your cargo capacity to half. :D
    Damn,
    Bakit nga ba ganun.... The Leaf Spring is used for heavy cargo...... what you can do to minimize this is by decreasing your tire pressure by 10% kasi if the Michellin LTX/AT pressure is 44psi medyo matagtag yan....
    Stroker - yan bang highlander na sinasabi mo eh yung XTRM2000 or the Xwind.... yung suspension nang XWIND medyo maganda na yan.. (nang kaunti).
    Inverting the leaf spring will reduce the tag tag pero there is the risk of breaking the spring in case of heavy cargo.....
    The big blue book does not recommend removing or inverting..... unless you want the comfort.....
    That is the problem with Leaf Spring.... If you take a look at the CRV the suspension is good but pag punuan na.... bagsak ang likod (no flames please)
    Sana nakapag linaw ako kahit papaano...
    Pero the other guys here si very knowledgable.... I know one person who done the inverting spring (PM. Bulldog) our very own El Presidente who has the 4X4 fuego.... I cautioned him on the strain on the leaf spring....
    good luck.... how is your 2nd seat (kung Highlander TBR160 yan) kung Xwind - sarap upuan
  13. FrankDrebin Guest
    Ungas,
    Quote=Nabasa ko lang that it will reduce your cargo capacity to half.
    grabe pala ang sacrifice. kapag walo yung nakakaupo eh apat na lang pwede.
    boknoyxtrm2001,
    Quote=what you can do to minimize this is by decreasing your tire pressure by 10%
    ganyan din po ang ginagawa ko para lumambot ng kaunti. pero kapag kargado naman ang tsikot eh ok na yung tagtag.
    Ano po yung Highlander TBR160?
    Frankdreblin....
    the TBR160 (yata ha I forgot the coding) is the Highlander series like mine... yung TBR161 eh yung crosswind
    Pag maylaman naman wala na tagtag...sarap may laman.... sa likod
  15. FrankDrebin Guest
    boknoyxtrm2001,
    pwede po bang palitan ng magwheel yung sasakyan natin?
    para kasing unique yung magwheel.
    Frank,
    Pwede sir.... kaya lang... walang katulad yung sa atin medyo matapang na ang dating... pwede basta 4 stud.... pero wala pa ko nakita na XTRM na nagpalit nang magwheels
    yung mga lower SLX,SL nag palift tapos gulong at magwheels nang xtrm ang ginamit....
    nakakatuwa nga
    Ungas,
    Parang ganun na nga ang kalalabasan. But as sir boknoyxtrm2001 emphasized, pwede ka pa magkarga upto 8-10 person but there will be the risk of further damage to your suspension system.
    Suspension modification has to be done in a right way, like changing your leaf springs for an aftermarket one. Which will drastically improve ride comfort and at the same time give you ample cargo capacity.
  18. FrankDrebin Guest
    boknoyxtrm2001,
    so pwede pala...thanks!
    BTW, ano nga pala mga acces. ang mga nainstalled nito po? I'm thinking of having a rear door reserved tire mount. Naaawa kasi ako sa reserva.
  19. FrankDrebin Guest
    Ungas,
    sa isang honest opinion niyo po, gagawin nyo ba yun if XTRM ang ride niyo?
    boknoyxtrm2001,
    XTRM2000 ang ride na tinutukoy ko (hindi Xwind). Matalbog sa 2nd and 3rd rows eh; layo ng ride sa CRV.
How to Improve the ride of Highlander XTRM
