Results 21 to 28 of 28
January 11th, 2009 09:32 AM #21
January 11th, 2009 09:47 AM #22
inconclusive po yang pic mo sir...
your environment is still bright... a little bit of more distance, and taking a pic should be manual and no flash...
I have seen xwind with less glares, but yang kunting glare will be a bad glare on dark provincial roads... our eyes accept more light on darker environments...
fogs are meant to scatter lights and fogs are worst from more distant view on HID, kasi expose lahat yung lamp. kung malapit kasi, natatakpan na yung fog sa bandang itaas ng housing niya...
I suggest improvize kahit yung fog man lang...
January 11th, 2009 09:53 AM #23
January 11th, 2009 10:09 AM #24
3950 first pair, 3500 2nd pair...
(Clear Lens Halogen Projector, DOT cut off, H3 base) 3k pair
more on this forum po...
http://www.grupotoyota.com.ph/board/...ba7017d6a9bc4b
sign up membership lang muna
headlight convertion bi-xenon.
January 11th, 2009 10:56 AM #25
January 12th, 2009 03:33 PM #26
* sir SQ thank's, will try to do that.
* sir rion, iyung kit po ba is i aadopt lang (any head light)or kailangan pang i modify iyung head light itself? & x2 sa question ni sir SQ if may high/low beam? tia
January 13th, 2009 02:52 AM #27
basta bi-xenon, may low/high po yan. it's not the Lights that will trigger the low/high beam, but a solenoid that will switch the cutoff on or off...
so an H3 can be a low/high. but unlikely, D2S type ata gamit ng Bi-Xenons.
but the pics I posted are all single beams, idealy for fog lamp improvize... except for the main headlight convertion kits from north customs...
Xiaomi E-Car
